Old 02-09-2003, 05:59 PM   #1
lug nuts bambi
hello,
have a new 2003 bambi. owners manual says to check the lug nuts at first 50 miles with tq to 85 lbs. there seems to be about 1/32nd in play in the head of two of the lug nuts. is this normal? also are these nuts or are they bolts that go into the wheel hub? the tq seems good at 85 lbs.
thanks,
david h
david h is offline   Reply With Quote
Old 02-10-2003, 07:12 AM   #2
LOST , Hawaii
Assuming the torque wrench is right there should be no movement anywhere with that much torque.
John
74Argosy24MH is offline   Reply With Quote
Old 02-10-2003, 08:59 AM   #3
1996 30' Excella
Brighton , Michigan
The wheel nuts on my Classic are a standard wheel nut with a chrome cover which is held in place with a crimp. After removing or retorquing a wheel the cover will become loose or fall off. My trailer is now missing 7 or 8 nut covers. This spring I will replace all my wheel nuts with chrome plated acorn solid wheel nuts avaliable from most auto parts stores or tire stores.
apple 1 is offline   Reply With Quote
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
Recent Bambi owners wanted! rluhr 1997 - 2004 Bambi 82 09-01-2009 08:55 PM
Rusty chromed lug nuts nickcrowhurst Wheels, Hubs & Bearings 14 08-02-2004 06:52 AM
Lug nuts wiggle? Kistler Axles 3 03-19-2004 03:54 PM
The new Bambi is in the Yard Ed & Nancy 1997 - 2004 Bambi 23 04-06-2003 12:37 AM
