Old 08-21-2009, 07:03 PM   #1
JLGT5107's Avatar
1965 20' Globetrotter
Fairfield , Connecticut
Lucky brakes...broken spindle
Decided to tow 65 gt 20 miles from place of purchase. I jacked both sides, bearings looked good and wheels tuned freely with just a slight scraping noise. Experinced some lurching on 2 occasions at about 25mph. Got home and have now disassemled hub. Pictures tell the rest of story. I should have followed my first instinct and gone with flatbed delivery
ID:	85842   Click image for larger version
ID:	85844   Click image for larger version
JLGT5107 is offline   Reply With Quote
Old 08-21-2009, 07:38 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Ya Think? I don't see how that was done. Very interesting.
At least when you are done you will have complete brand spanking new brakes.
Brian
SuEllyn & Brian McCabe
Old 08-21-2009, 07:57 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I don't think the flatbed would have helped very much; Looks like the damage was already done before you bought it. Either way, you still need a loaded backing plate assembly.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-21-2009, 09:35 PM   #4
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Yes, get the whole backing plate package. While you are at it see that you don't need a new axle. I put new brakes on our '66 Trade Wind last year and planned for new axles this year. But discovered that the work I did putting new brakes on was for naught. The old backing plate doesn't fit the new axles (tandem). If you were closer I'd give you the new, slightly used brakes but the shipping would not be worth it. Check the axle though.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 08-22-2009, 09:26 AM   #5
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Do your new axle and brakes all at the same time. Makes sense, saves time and frustration later and gives you peace of mind......just my two cents worth
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 08-22-2009, 04:35 PM   #6
JLGT5107's Avatar
Thanks for replies. I'll do the whole thing together for efficiency and peace of mind. I posted a thread in "axels" with pictures of axel movement. When I jacked the trailer it appeared to move about 1 3/4" but when i tested the swing arm it barely moved 1/2"
Old 04-26-2010, 10:28 PM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
This was common issue for single axle Airstream trailers in mid- 60's (64 - 66 I think) that were from 20 to 42 feet in length.
If you haven't done so already replacement of the axle assembly with a higher capacity one is needed.
>>>>>>>>>>Action
spindle nut socket size Ruben J Axles 4 04-20-2009 09:12 AM
We're lucky! codybear Off Topic Forum 3 12-19-2006 05:59 PM
Could I be this lucky? pinkflamingoes Clearcoat, Exterior Paint & Trim 7 03-26-2006 12:25 PM
Spindle Replacement ? morrism11111 Axles 2 08-23-2003 06:31 PM
