Old 02-24-2007, 09:25 PM   #1
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Question Lube interval for a '06 Classic
I was told that my trailer, 06 Classic 31, had permanently lubed axles. Now I am being told they do not and need to be done every 10,000 miles. One problem I already have 15,000 miles on the trailer.
So does anyone really know if I have sealed bearings? Do I need to replace them? do they need to be repacked now? or at the one year anniversary?
Michelle TAC MT-0
Sarah, Snowball
Old 02-24-2007, 09:49 PM   #2
_
"permanent" well that is a long time...
since you have an 06,
you must have dexter axles?
they make at least 3 styles...
http://dexteraxle.com/i/u/1080235/f/...gs_4-06_72.pdf
1. conventionally lubed
2, 'e-z lube' (via a zerk like fitting)
3. 'nev-r lube' a sealed bearing race good for up to 100,000 miles or 5-years.
#3 is NOT a lifetime bearing set but rather a 'no service' set and they do need to be replaced based on mileage or years...
in your purchase paperwork, should be a yellow sheet/card...
labeled the airstream certified performance check-out...
this sheet has listed all major bits (frame, axles, locks, applicances, lp tanks) along with serial numbers...
so this sheet contains the serial numbers for your axles...
dexter has a website. you can call them or email them with your axle numbers.
http://i.b5z.net/i/u/1080235/f/6-8K%...0_res_2-05.pdf
you can download the complete dexter service guide and even the installation manual for your axle model...cool!
http://dexteraxle.com/i/u/1080235/f/...-06_72_res.pdf
why not get the correct answer from the maker?
alternatively you can remove a wheel and center cap and look...
fyi...per airstream/for warranty purposes a hub/bearing inspection is required at 6 months.
did you have this done? if not, your hubs are out of warranty sad but this is in the paperwork.
there are many threads here on the +/- of bearing repacks and frequency...
and NONE of them matter IF you have the never-lube 100k style...
i had mine (henschens) inspected at 6 months (9-10k) and repacked at 25kmiles...
cheers
2air'
Old 02-26-2007, 02:11 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Permanently lubed axles or bearings?
The axles will never need lubrication. The bearings are another story as outlined above.
>>>>>>>>>>>Action
Old 02-26-2007, 02:20 PM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Dunno, looks like something is going on...see post #1:
http://www.airforums.com/forum...ade-30441.html
Old 02-26-2007, 02:40 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
Michelle does have Dexters -- although they were only used on the '06s between mid-summer '05 and about February '06. Suspect she'd confirm her build date within this period. My Safari was built in August '05 and has the Dexters -- drum instead of disk brakes tho.
5 meter Langford Nahanni
Old 02-26-2007, 03:55 PM   #6
_
Originally Posted by Canoe stream
Dexters....were only used on the '06s between mid-summer '05 and about February '06.
can you confirm this bob?
while it was repeated here several times that the dexter switch was temporary,
my info suggests they are STILL using dexter.
the henschens aren't 'canada certified' yet.
cheers
2air'
Old 02-26-2007, 04:33 PM   #7
2air' -- No I can't. I have only a general recall of posts here at the Forums. Like the news about sealed bearings it is hard to keep up with exactly what the factory is doing. If no Canada certification is in place yet, one would have to wonder if/why they'd be using any Henschens. Tell us more ...
Old 02-26-2007, 06:31 PM   #8
skyvalley's Avatar
2006 25' Safari
Desert Hot Springs , California
2air excellent post
2air,
Your post #2 is excellent. Thanks for the well researched info...
John
skyvalley is offline   Reply With Quote
Old 02-26-2007, 06:46 PM   #9
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Dexters
What is the difference in these axles.Mine was built I think around October or november november of 2005.I got my 05 in feb of 2006.Just curious as I do not have the Aistream with me anymore.I parked it in town for the summer at the parents house.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 02-26-2007, 07:15 PM   #10
Somewhere , Indiana
cheers
2air'
2air,
The Henschens are Canada Certified (AKA: CSA Approved) - oddly enough - using Dexter brakes!
The rest of your info is spot on - including Airstream still using Dexter axles!
Additionally, Henschen does NOT offer the Nev-R-Lube bearing!
Regards,
Henry
axleman is offline   Reply With Quote
Old 02-28-2007, 08:08 AM   #11
Keymar , Maryland
bearings. I am going to go see if the info I really need is in my owners packet today. If not I will be at the factory in a couple of weeks.
Michelle TAC MT-0
Sarah, Snowball
Old 02-28-2007, 08:09 AM   #12
Keymar , Maryland
My trailer was built in late march of 06. I have disc brakes. Works great when properly synced!
Michelle TAC MT-0
Sarah, Snowball
Old 02-28-2007, 08:47 AM   #13
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
If it were me, I'd just call or email AS customer service, give them the serial number, and they'll tell me what axles/components I have.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
P-30 Transmission Fluid change interval crazeevw General Motorhome Topics 11 12-08-2011 03:59 PM
Wheel & Hub Service Interval moosetags Axles 15 07-10-2007 08:38 AM
lube for door hinge? edwmart Doors & Locks 7 07-07-2006 04:01 AM
How do I lube the tongue jack 63air Jacks, Stabilizers, Lifting and Leveling 4 06-29-2006 10:32 PM
window crank lube Jabba Windows & Screens 7 06-08-2006 08:22 PM
