Old 08-17-2007, 11:20 AM   #1
1963tradewin's Avatar
1963 24' Tradewind
, , Minnesota
Lower mount on shocks won't hook up to new axle
I just got a new Dexter axle. The axle will bolt up fine with some drilling but the lower bracket for the shocks is welded to the torsion arm. The new axle torsion arm does not have a bracket. Does anyone know if I can weld a new bracket on the torsion arm or will it be damaged?
1963tradewin is offline   Reply With Quote
Old 08-17-2007, 11:25 AM   #2
richinny's Avatar
2011 34' Classic
search for "dexter". i believe you have to cut off the old plates and weld them on the new.
Old 08-17-2007, 12:56 PM   #3
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Wait a few weeks ....
Wait a few weeks. A friend and I are thinking about bolting a lower shock absorber bracket onto a Dexter axle that will go under a 1964 19' Globe Trotter. My situtation should be nearly identical to yours. The new axle has not yet arrived, and once it does we'll need a few days for head scratchin' , measurin' and pencilin'. If it works I'll post photos and details here. If it doesn't you won't hear a peep.
Today it's all just a conception in progress, but if you don't have ants in your pants, wait a few weeks and see if we come up with something useful and perhaps easier than welding.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 08-17-2007, 01:35 PM   #4
1963 24' Tradewind
, , Minnesota
axle
By the looks of things I think I would rather weld then have bolts. Maybe bolts would be better i dunno. Im trying to have her fully completed in 20 days. Long way to go What im wondering is if i weld it will it heat up that part of the axle and cause damage down the road? I know it might sound like a stupid question but im new to these torsion axles. thanks for the responses 1963tradewin
Old 08-17-2007, 03:54 PM   #5
1975 27' Overlander
High River , Alberta
Since you have the old axle, cut off the old brackets (use an angle grinder to grind through the welds), clean them up, and have them MIG welded to the new. MIG is fast and the heat is far more localized than with stick welding; I'd be very surprised if problems resulted.
A friend made up and welded brackets for my aftermarket axles. Using the originals will be easier, and they have the stepped 5/8" diameter studs. The shocks do make a difference, and I recommend them.
AlbertF is offline   Reply With Quote
Old 08-17-2007, 07:51 PM   #6
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Use the "search" button above and find many threads on axles - and many different answers. However, I believe the consensus is that you CAN weld on the torsion arm without damage. Other questions about axles tend to excite a few people.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 08-17-2007, 08:03 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Only a few people? your propensity for understatement is overwhelming.
Seriously, you can weld on the torsion arm, as long as it's done in a fast manner, don't dawdle with the welder. When I talked to the dexter reps, they told me to make sure I called them before welding anything to the axles, so the info could be noted, and not void the warranty.
Old 08-19-2007, 01:47 PM   #8
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Ron (pizza chop) did this
So yes weld away.
'77 Sovereign Intl 31' CB
Old 09-01-2007, 10:42 AM   #9
1963 24' Tradewind
, , Minnesota
Thanks for the advice li pets it worked out great
Dexter Torsion with no lower shock mount? Aktundra Axles 7 02-11-2012 11:15 AM
HELP! Lost the 'HOOK' to unlock/lower awnings! lovetofly Awnings 8 06-29-2010 03:55 PM
Hook up OR Not Hook up while camping purman Boondocking 29 08-18-2009 06:42 PM
Shocks, shocks and more shocks Inland RV Center, In Commercial Listings 1 05-26-2009 03:37 PM
Shocks or no shocks with new Dexter Axles? nick6930 Axles 5 04-13-2009 03:41 PM
