Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 07-03-2013, 08:56 PM   #1
1976 27' Overlander
San Marcos , Texas
Looking For Suggestions, Rusted axle
My uncle has recently passed on, leaving me this overlander airstream. I don't know a single thing about it, but I am anxious to fix it up. First thing is getting it to my place to work on it; it's been sitting out on a deer lease for about 6 years and the axel is pretty rusted. I plan on replacing the tires of course, but I am curious of what else I should do before attempting to move this thing a couple hundred miles. Any thoughts? Also where do I look to find the year/model.
loco_greengo is offline   Reply With Quote
Old 07-03-2013, 09:16 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy!
There should be a metal VIN plate on the outside. Look on the streetside (driver side) below the windows.. By the VIN you will be able to check the Airstream.com site or post here for evaluation.
Jack the Airstream (AS) carefully.. only where marked. On your camper, the proper method is to use a ramp then back up or pull the camper forward on one tire.. that will lift the other off the ground to change.. repeat on other tires... one at a time.
Note how much the tire 'drops' when the load is off.. Do NOT jack on the axle because you will damage it permanently. You can 'jack' next to axle, carefully, by jacking on the vertical plate where the axle is mounted. Do not get underneath ...
As long as the angle of the axle is correct, they should be ok.. at least for a tow home... make sure you have good brakes..
This may be a blessing...hope all is well.. send more pics!!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-03-2013, 09:31 PM   #3
Moderator Emeritus
overlander64's Avatar
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Looking For Suggestions, Rusted axel
Greetings loco_greengo!
Welcome to the Forums and the world of Vintage Airstream ownership!
The VIN tag on most Vintage Airstreams is on either a cast plaque or an aluminum plaque immediately to the right of the door either at belt-line level or rub-rail level depending upon era. Later model Vintage Airstreams have VIN plates behind the LP tanks below the front window. I have attached pdf files containing information on interpreting Airstream VINS.
The Henschen Dura-Torque axles appear to be original to the coach, and based upon the length of time that it has remained parked they are likely in need of replacement prior to contemplating many road miles. To get the coach home, you will want to repack the wheel bearings which will give you the opportunity to inspect the brakes as well. The brakes are likely Kelsey Hayes or Dexter, either of which have ready parts sources. You may find that you only want to make repairs necessary to get you home, and hopefully you will find the only problems to be rusted springs (available in replacement kits) or one or two other small components . . . it is always best to compare the cost of needed parts with the cost of fully loaded backing plates as it doesn't take too many individual parts to approach the cost of a fully loaded backing plate.
You can assess the condition of your coach's axles using the information in this link. You can also learn about the configuring of a hitch for your Vintage Airstream at this link.
Good luck with your Vintage Airstream!
Kevin
Kevin D. Allen
AIR #827
1964 Overlander International
Old 07-03-2013, 11:26 PM   #4
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
"Do NOT jack on the axle because you will damage it permanently."
I don't want to hijack this thread, but why not jack on the axle, assuming it's a single axle? Is the axle tube too thin, potentially resulting in a bent axle?
DryFly is offline   Reply With Quote
Old 07-03-2013, 11:58 PM   #5
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Axles tandem or single
DryFly, The trailer we are talking about here has a tandem axle set as it is a longer & heavier trailer. But if it has two axles or one the answer is the same. Yes! If you jack the trailer up under the axle tube you could bend the axle and create a dangerous tow issue that might even cause axle failure at highway speeds. The axles are Henchen OEM and the tube itself is a torsion axle tube. (It has rubber rods inside that are installed to cause the axle to cushion bumps). This is a different designed axle than ones with springs. If the tube is damaged it could cause the tires a serious alignment issue that might cause tire or axle failure to result. Those original axles will need to be replaced ASAP as from sitting in one spot for years the rubber rods have taken a set (hardened) that has caused them to lose the ability to absorb road shock from bumps or poor road surfaces and can cause the trailer to shake itself apart due to vibrations that can caused popped rivets or even frame failure. Hope this answers your question. Ed
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
BIGED52 is offline   Reply With Quote
Old 07-04-2013, 02:55 PM   #6
. , At Large
There is a SOB trailer at the shop right now with spring type axles that was jacked up by the axle. It has a bent axle now because of it, which will have to be replaced. Torsion axles are not the only ones that can bend when jacked improperly.
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
New axle for 1969 Caravel scottwtalley Axles 10 12-17-2011 08:01 AM
