Old 08-07-2009, 08:08 AM   #15
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Hey, Doug: is that the place that is also a Dexter dealer?
assuming you put a "conventionally" sprung axle on the '56. wonder if a torsion axle would cost similarly...
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 08-07-2009, 08:18 AM   #16
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
Axles
I took my 56 caravanner all the way from boston to Platsburgh NY and back again and at the time it was the original.
Grease it up well, make sure your tires are inflated well and cross your fingers as you take it over to the man who will replace it for you. Take it slow over bumps.
Go check out some of the wrecks that Rob Baker has pulled out of backyards and ones that have been buried in the dirt. For a one-way mission, grease up and be cautious.
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 08-07-2009, 08:20 AM   #17
1956 22' Caravanner
Yep
I've got a dexter on mine. He's got a whole catalog of options. The owners name is Evin, good guy.
There's also a horse trailer guy in Medfield, but he was nearly three times as expensive for the same job....
Old 08-07-2009, 08:23 AM   #18
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Definitely- replace the axle, don't bother upgrading certain parts on the old one. It will be a custom order, which is what Dexter expects. Get your measurements right and the axle will be right. -tim
tphan is offline   Reply With Quote
Old 08-07-2009, 09:04 AM   #19
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
In 61 the California trailers had a welded axle, The Ohio trailers had a bolt on axle.
My axles are original on my 61 and I am in no hurry to replace them.. My test for trailer vibration etc is how long the mantle stays on the gas light and it usually several thousand miles. The brake assemblies have been replaced.. I have found complete assemblies for as little as $42.00
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 08-19-2009, 06:28 PM   #20
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Jason, your X looks same as my '64. Just the 4 bolts, + shocks, and they drop out. Only problem I had was one swing arm was up so high it blocked a bolt from comming out, had to cut the bolt. Had to pull my X to replace the floor, just put it back in tonight. 2 guys 1 hr. I took the measurements to order a new one. As far as I can tell we have to buy all new right out to the wheels, none of our original equp. will interchange with a new X. Real bummer, all my brake/drum equip. looks as new.
putback is offline   Reply With Quote
Old 08-19-2009, 07:45 PM   #21
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
You might want to check with Colin Hyde, of the VAP fame. He is not with GSM any longer and is running his own business now and will order axles for you. His email is colinhydeairstream@gmail.com. I don't think he has his web site up yet.
Safari axle Ramp Axles 6 06-12-2008 05:41 PM
Safari gets new axle samb Axles 8 06-06-2008 01:48 AM
Axle Replacement on Safari 23 kneal Axles 18 02-27-2007 02:47 PM
'56 Safari Axle fdelaney Axles 3 08-07-2005 08:36 PM
I sent this 67 Safari to England and look at it now! RichardT Our Community 3 02-23-2005 08:40 PM
