12-16-2005, 07:48 AM
1972 31' Sovereign
Visalia
Looking for an axle
Hi, My name is Mike Bunker and my wife is Denise. We live in Visalia CA. ( cental valley, CA) We have a 1963 24' tradewind, which was gutted when we bought it 3 years ago. We remodeled it leaving it an open floor plan so we could use it as our office. I just aquired a 1972 31' sovereign with a broken rear axle. In searching for an axle, I came across this site an thought it would help me with my restoration project. Any hints would be appreciated.
Thankx much
Michael B.
12-16-2005, 07:56 AM
Naysayer
1968 24' Tradewind
Russellville
, earth
Welcome aboard. I suggest using the search feature. Type in axle and you will have days and days of reading ahead of you. Lots of good advice to be had.
12-16-2005, 08:01 AM
2002 25' Safari
Dewey
One place I would check with is Inland RV http://www.inlandrv.com/ . Andy is very active on this forum and knows axles. They are located in Corona, CA. BTW he is currently doing a makeover of a trailer for a couple from Visalia also.
Richard
12-16-2005, 08:43 AM
Somewhere
, Indiana
Choices
First let me say, welcome to the forums!
There are several good choices for a replacement axle(s) in addition to Inland RV:
www.dexteraxle.com
www.al-kousa.com
www.reliabletool.com
www.axisproducts.com
I agree with researching the forums database. There is even a specific section for axles/brakes/wheels/tires - click on the "forums" tab.
Happy hunting!
Regards,
Henry
12-19-2005, 11:02 AM
Moderator dude
1966 26' Overlander
Phoenix
Weighing in on the issue!
Mike,
I would also suggest weighing the unit. Since it has been modified, the weight may be different. And you will need to anticipate the greatest amount of "stuff" that will be in the unit and then add 10%. This will determine the weight rating for your use.
Too little rating and you may experience premature failure. (I hate when that happens)
Too much and the insides may be shaken such that things come loose. The total extreme would be that rivits loosen up.
The '71 will have a torsion axle with electric drum brakes. The original manufacture was Henschen. Inland RV carries that line exclusively. And as noted above there are other torsion axle manufacturers too. Also you may want to consider new brakes as included with the axle. (versus a bare axle) You will have drum size choices in addition to the disc versus drum. The cost will usually be higher for more efficient stopping power. So consider wisely the future needs and build from there.
>>>>>>>>>>>>Action
12-19-2005, 11:24 AM
Somewhere
, Indiana
True - But
>>>>>>>>>>>>Action
This is true, but I believe the current Airstream axle provider is Dexter Axle!
Regards,
Henry
12-19-2005, 04:31 PM
Moderator dude
1966 26' Overlander
Phoenix
The original axle manufacturer was Henschen for that year. Henschens are still available at one source only. And I believe more current model years of Airstreams are Dexter.
A Dexter should fit and so will others. So mods may be necessary. Even with a Henschen (depending on model and year) a modification may be necessary.
>>>>>>>>>>>>>>Action
12-19-2005, 05:01 PM
1958 30' Sovereign of the Road
Plymouth
, New York
My Axis axle
I just ordered, not too long ago, an Axis axle through Colin at GSM Vehicles. They put Axis under Vintage Thunder, Airstream Life's project trailer. Our Axis is for our 65 Caravel. Listen to www.theVAP,com, I think either Episode 3 or 4 for some information on axles. Good luck.
Rob
12-19-2005, 05:13 PM
1956 22' Flying Cloud
Durango
Action
Thats not entirely true - if you know exactly what you are looking for you can buy direct - Inland provides that service of getting the exact specs - Henshion will not provide you an axle for a 66 Overlander - but then will provide you with an axle that is x long, x drop etc etc....
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
12-19-2005, 05:57 PM
Somewhere
, Indiana
Are you sure?
Ken,
I think that used to be the case however, I thought they switched to supply OEM's only! That sure seems to be the flavor of the Henschen website. Please read the new header at the top of Henschen's homepage stating " Servicing The OEM Client"
Did you order a Henschen axle from Henschen lately?
Regards,
Henry
12-19-2005, 06:00 PM
Moderator dude
1966 26' Overlander
Phoenix
I thought a new Henschen axle replacement for an Airstream was only available from one source. And Henschen does not do retail.
At least that was my understanding.
>>>>>>>>>>>Action
12-19-2005, 06:27 PM
Durango
Welp - maybe things have changed - my understanding is the reason Inland picked it up is because they were getting bombarded with Vintage Airstream folks wanting axles and they had to figure out what they had. Its also my understanding that you can call them for later model Airstream axles as the deal with Inland was only through a certain year.
Course perhaps all that has changed and no I've not ordered any axles from them lately - my info was good as of a year or so......ya know what they say - the only constant is change...........
Ken J
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
12-19-2005, 07:43 PM
Moderator dude
1966 26' Overlander
Phoenix
"That year" would be 1980.
>>>>>>>>>>>>>>Action
12-22-2005, 05:37 AM
Somewhere
, Indiana
I want to understand
OK - let me make sure that I have got this right - if Andy at Inland is the "exclusive distributor" for Henschen axles from 1980 and prior. With Henschen's website appearing only sell to OEM's-
Am I correct to say that if you own an Airstream 1981 or newer, and desire a Henschen axle, you can call Airstream, parts and service, and they will help you?
Perhaps someone can chime in and educate me - thanks!
Happy Holidays,
Henry
12-22-2005, 06:00 AM
Moderator dude
1966 26' Overlander
Phoenix
Henry,
It doesn't appear that Henschen sells retail. I am sure they would refer one to a retailer based on their website. And I thought you would know, since you retired from that business.
>>>>>>>>>>>>>Action
12-22-2005, 06:12 AM
Somewhere
, Indiana
Nope
Action,
When I retired - Henschen would still sell the newer axles (1981 and up) direct to the public (prior to the OEM change that they have made).
What I don't know is what an Airstream customer, 1981 and newer, does to get an axle - is Airstream Parts and Service handling this or does Henschen make exceptions to the OEM rule (I kind of doubt it).
Any insight would be appreciated - I love to learn!
Henry
12-22-2005, 06:16 AM
Just an old timer...
2004 22' Interstate
Tipton
, Iowa
Henry, a suggestion: please give Airstream parts a call, ask them your question, and share the answer with us! Both you and the membership will get the answer from the horse's mouth instead of having to speculate!
Roger
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
12-22-2005, 06:25 AM
Somewhere
, Indiana
I may
Roger,
I was hoping with the thousands of members on the forum, that one that has encountered this situation might chime in to educate us.
However - if not - I just may call! Good suggestion partner!
I pride myself on shooting straight - if I don't know, I ask.
Regards,
Henry
12-22-2005, 06:30 AM
2004 22' Interstate
Tipton
, Iowa
I think it would be a good idea. It would certainly be more authoritative than one of us saying "well, I think..." and it would get an answer to the question much more quickly than waiting around for someone who's done it to answer.
Roger
12-22-2005, 10:36 AM
Somewhere
, Indiana
Roger
Roger,
Good point! I think that right after Christmas I've got a call to make.
Thanks for sharing!
Happy Holidays,
Henry
