Old 03-06-2008, 08:55 AM   #1
Barkingdogg's Avatar
Newcastle , Oklahoma
Looking for '67 Caravel axle choices
I'm in the market for a new axle for my 67 Caravel.
I asked these questions via email and received a quote:
I'm in the market for a new axle fo my 67 caravel.
Will bolt holes match & shocks mount the same?
I want a total axle with new hubs. They are currently 10". Is it possible or advantageous to go to a 12".
What would be the down angle I would need?
What would be the cost for axle & shocks shipped to Newcastle, OK 73065.
John Ford
John:
Shipping to your zip code is $228 Axle will be 3200-3500# 12" brakes/drum 6 lug on 5.5 pattern 35 down angle on the torsion arm, shock brackets loose for locating in respect to your shock mounts, you will need to drill 1/2" holes in the mounting plate as your old holes will not line up, we will provide the mounting hardware.
Axle $750 complete
Shocks $30.95 each
4 weeks lead time on the axle
Thanks...Inland RV Parts
800-877-7311
Would this axle be too beefy for my AS?
Thanks in advance
Barkingdogg is offline   Reply With Quote
Old 03-06-2008, 09:48 AM   #2
Sheridan's Avatar
1965 17' Caravel
Mountainous , Utah
Check the stamped plate on your old axle for the weight rating. Your 67 Caravel's dry weight is 2450 lbs, 200 lbs more than my 65 Caravel at 2250 lbs. The axle weight rating may have moved up accordingly. Try this link for more info on Caravel axles.
'65 Caravel - Axle Damage
Dan
Sheridan is offline   Reply With Quote
Old 03-06-2008, 09:53 AM   #3
John Ford
John:
Axle $750 complete
Shocks $30.95 each
800-877-7311
Thanks in advance
3200 pounds is a good upgrade. 3500 pounds is a maximum, but only if you will always travel with a heavy payload.
The original rating for your Caravel was 3000 pounds.
Old 03-06-2008, 10:17 AM   #4
Do you make a 3000lb axle?
And should I just go with the 10 hubs?
john
Old 03-06-2008, 10:38 AM   #5
john
John.
Yes, we also carry 3000 pound axles for the Caravels.
Old 03-06-2008, 11:13 AM   #6
john
John.
For your 67, you can go with 10" or 12" brakes.
Old 03-22-2008, 12:19 AM   #7
1967 17' Caravel
1959 17' Pacer
Corrales , New Mexico
Andy, I need to order the exact same thing for my 67 Caravel -- what are the advantages/disadvantages of 10" vs 12" brakes? Does the TV make a difference (05 Pilot)?
And is there any reason to choose the 3000 lb axle over the 3200?
Corraleno is offline   Reply With Quote
Old 03-22-2008, 07:12 AM   #8
The 12" brakes offer more "stopping" power. The cost is the same.
The original axle has a 3000 pound rating. A 3200 pound replacement offers a little more pay load capacity. A 3500 pound replacement is for those owners who carry a "large" pay load.
For the average owner, 3200 pounds works just fine.
Old 04-01-2008, 05:30 PM   #9
Tom O
Toldfield's Avatar
1966 17' Caravel
Altadena , California
The Wheels Didn't Fall Off
I have been reading about Caravel axles here for a while and getting a little concerned about the 40 year old one on our trailer. I called Inland RV a while ago and ordered a new axel. Yesterday I hauled Bucky down to Corona and asked if the new axle could be installed by noon. After the laughing subsided I went home. At 2PM Greg called and told me it was done. I picked the trailer up this morning and everything is great. They did a great job very quickly and pointed out a few things I can work on while I'm fixing everything else. We replaced everything and had the shock mounts redone. I could have done it myself and saved a bit, but at least I am sure it was done right. I was assured that the new axle will have no trouble carrying the keg of beer and ice...
Thanks Andy, I appreciate your help.
Tom O
"Badges? We ain't got no badges. We don't need no badges. I don't have to show you any stinking badges!"
CA-7
Toldfield is offline   Reply With Quote
caravel
'65 Caravel AC choices mpictx 1965 Caravel 6 07-03-2014 07:48 PM
mattress choices ? vajeep Upholstery, Blinds, Walls & Interior Finishes 6 02-23-2005 05:22 PM
Header choices ALANSD Mechanics Corner - Engines, Transmission & More... 5 01-31-2005 02:07 PM
choices choices technautica Our Community 7 12-23-2003 05:46 PM
need to install a water heater...choices? pixie Water Heaters, Filters & Pumps 6 03-20-2003 06:24 PM
