Old 09-07-2019, 09:56 AM   #1
Anahuac , Texas
Lift kit
Hey Y’all
I’ve been thinking about installing a lift kit on my 2007 30’ classic. I’ve read all the pros but haven’t seen a whole lot about axel alignment is this a big concern, or is there a kit that’s just bolt and go?
Thanks Steve
shb2777 is offline   Reply With Quote
Old 09-07-2019, 10:06 AM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Kit is bolt on and go, made by dexter. Not sure how you’d get out of alignment, it’s a drop in kit with limited adjustability.
Definitely recommend for a 30’. There are only upsides (no more dragging the rear skid plates). No difference in towing.
ID:	351550   Click image for larger version
wulfraat is offline   Reply With Quote
Old 09-07-2019, 10:29 AM   #3
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Comments based on one installation I did a few years ago. I have no alignment specs.
I scribed a reference line from the axle (prior to loosening axle bolts) up onto the frame. At install it was helpful and on some spots necessary to use a ratchet strap to position axle back in line to the scribe marks.
Dexter install info. https://www.dexteraxle.com/docs/defa....pdf?sfvrsn=12
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 09-07-2019, 10:56 AM   #4
2006 30' Classic
Sparks , Nevada
I just completed a lift on my 2006 30' Classic and like you was concerned about wheel alignment. Many on this forum have had good luck simply installing the kit and report no issues with alignment. I was hoping for, and trying to achieve, the same results. My experience is noted in Al&Missy's post Lift Kit Installed Today, page 6. I had used measurements and reference marks but could not line up exactly.
Two resources I used were published by Lippert Components and the Dexter service manual beginning on page 64. The Lippert document is excellent for ballparking where you stand but if there is any variance in your frame or tires the measurements could be off.
The alignment shop used the method similar to what is described in the Dexter manual, page 71 item 2, by dropping a plumb bob from the hitch coupler and the ends of the two front axle spindles. They initially found my installation off by 7/16" relative to the front coupler and frame. After adjustment they were able to get within 1/32" of being equal. The variables being the slotted holes in the axle top mount brackets and the slotted hole where the side bolts attach. Also, there is just a little bit of variance in the bolt holes so if you pick up a tiny bit here and a tiny bit there it adds up to a measurable variance. Centerline spacing between the two axles was adjusted to 33". A lot of this is greek to me but made sense when talking to the shop mechanics. Cost was $230, similar to what a few others indicated they paid.
Was it worth the effort and dollars spent? Considering I have a brand new set of Endurance tires installed I hope to have them perform and wear as expected. If I were to do this project again I would check alignment per the instructions in the Lippert document, tow the vehicle a short distance using chalk marks across the tread to identify any abnormal wear pattern and then make a decision to go to the alignment shop or not.
Reno Classic is offline   Reply With Quote
Old 09-09-2019, 11:06 PM   #5
Anahuac , Texas
Lift kit
Thanks y’all
I think I will give it whirl when I get some time and it gets a little cooler in Anahuac Texas. One more thing though, how hard was it to loosen those bolts?
Thanks Steve
Old 09-10-2019, 04:54 AM   #6
GCinSC2's Avatar
IIRC, some can be hit with impact gun, some have decent breaker bar access, a few are possible PITA. If you're a regular DIY'er used to busting a knuckle on a project you'll get it.
S/OS #001
Old 09-10-2019, 05:03 AM   #7
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
I'd like to add a lift kit to my Sport 16. Not something I can do myself. Do you think a well respected trailer (all kinds trailers, not specifically RV's) outfit be suitable to do this job?
Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
farafield is offline   Reply With Quote
Old 09-10-2019, 05:42 AM   #8
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
It’s not a hard job to do. Any shop with some basic skills and the willingness to do so should be able to complete this project.
Single axle trailer makes it super easy.
Here’s a couple of BLOG post form some I’ve done.
http://www.airforums.com/forums/blog...lift-kit-2901/
http://www.airforums.com/forums/blog...3fb-lift-3033/
Old 09-19-2019, 10:36 PM   #9
2016 30' International
redondo beach , California
Thanks to this thread we pulled the trigger.We just had Airstream of LA do the lift for us. $1,050.00 total cost.
No difference towing.
Big difference going in and out driveways.
Dramatic difference off the pavement and in the dirt in Temecula, CA among wineries and hot air balloons.
I would rank this among the top AS modifications after LiFePO batteries.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 09-20-2019, 11:47 PM   #10
Anahuac , Texas
Thumbs up Lift kit
Thanks Mythbuster88
Seeing post like this helps reinforce the decision process.
Thanks Steve
BAMBI LIFT KIT: Dexter K71-724-02 3" lift for #11 axle (19' Bambi) pstaro1 Airstream Classifieds 0 07-01-2019 10:03 AM
Should i lift the shell or not lift the shell.. prettybrent Repairing/Replacing Floor &/or Frame 19 09-04-2016 10:13 AM
1997, 34ft Classic: To Lift, or Not To Lift (its shell) mattler General Repair Forum 4 10-16-2015 10:40 PM
Air 'Bags' - too lift or not to lift JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 04-09-2013 10:09 AM
3/4 ton suburban with 6" lift kit lohidoc Tow Vehicles 13 06-17-2007 06:07 PM
