Old 08-30-2008, 07:31 PM   #1
mustang's Avatar
1999 27' Safari
Kent , Ohio
Kodiac Oilbath Hub
What is a Kodiac oil bath hub assembly? and whats the application? I just grease my bearings and I am on my way. I saw a picutre of it on an Airstream. Pro's and Con's if any.
mustang is offline   Reply With Quote
Old 08-30-2008, 07:58 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
An oil bath hub contains gear lube, rather than wheel bearing grease. Most I have dealt with have a sight gauge on the hub which is a translucent cap with a line circling it. As long as the gear lube is high enough to touch the bottom of the line on the bottom of the cap, there is enough.
It is generally used on heavy duty applications, such as semi trailers.
Old 08-30-2008, 08:03 PM   #3
mustang's Avatar
1999 27' Safari
Kent , Ohio
I now, but I saw this on a Airstream in this forum. I was wondering about any benefits but it would require changing rear seals and bearings right?
They are very common on front axles of semis and heavy duty applications like you said.
Old 08-30-2008, 08:05 PM   #4
1993 21' Sovereign
You could do it, but I would be concerned about oil leaking onto the friction surfaces of the brakes, and causing reduced braking.
Old 08-30-2008, 08:09 PM   #5
mustang's Avatar
1999 27' Safari
Kent , Ohio
Thats what I was htinking , more of a liability. It probably is best to stay with my greased wheel bearings they have lasted this long.
Old 08-30-2008, 08:31 PM   #6
Vintage Kin
Fort Worth , Texas
Oil bath hubs are on steer and trailer axles on big trucks. Hard to beat for ease of inspection (and any oil addition), plus, one knows "immediately" if they are going dry.
They would be my preference if the ones to fit these light duty axles have a long, reliable service life.
Are These Your Hub Caps? neillop Wheels, Hubs & Bearings 15 05-25-2011 07:47 AM
Rims and hub caps sigv Commercial Listings 3 04-09-2006 04:10 PM
Hub Help frozen chosen Axles 6 05-01-2005 05:55 PM
Hot hub Pahaska Axles 5 04-22-2005 04:29 PM
