Old 02-08-2009, 03:10 PM   #1
1968 22' Safari
port st lucie , Florida
Jacking up a '67 safari
After reading most of the posts on axle replacements, esp on older Airstreams, we decided to give our trailer a good going over to see where we stand. We are having trouble finding a spot to jack the trailer up to get at the axles. We've read there is supposed to be a section underneath to put the jacks on, but we are unable to find it, and we are
hesitant to jack it up and cause more problems than we may ultimately find.
Anyone out there ever replaced the axles on their 67 safari, and if so, where did you jack it up?
Any suggestions would be helpful.
David & Janet
captmorgan is offline   Reply With Quote
Old 02-08-2009, 03:25 PM   #2
David & Janet
The axle is bolted to an "axle mounting plate."
That plate is welded to the side of the frame, for the purpose of axle mounting, and protrudes below the frame.
You can place a floor jack or a bottle jack on the axle mounting plate, rearward of the axle.
You can then add a "jack stand" to that same place, then change the axle or brake work or whatever.
CAUTION: Make sure you use good jack stands, to support the weight. Also when the trailer is up on jack stands, DO NOT allow anyone to open the entrance door or get inside the trailer.
Old 02-08-2009, 03:32 PM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Where the axle and the shock absorber attach is the place to jack up your trailer. What I did was jack up the trailer on both sides brace with jack stands and use to floor jacks to drop and lift the axle into place. I also put stands on the corners of the frame just in case it shifted. Hope this helps.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Our '56 Safari (aka Our Retirement Home) SafariSteve 1956 Safari 41 09-04-2013 05:55 PM
1968 Safari 22' :: 1968 Airstream Safari Darrengj Airstream Registry Discussions 0 08-19-2011 08:32 AM
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 08:31 AM
New Safari owner 2001sport 1966 - 1968 Safari 10 06-24-2011 11:30 AM
