Old 03-19-2016, 08:49 AM   #1
GuitarmanFL's Avatar
1972 27' Overlander
1971 31' Sovereign
Orlando , Florida
It's a question of degrees: New Rolling Chassis - 73 27' Overlander
Hey All:
Need some help here.
I have a 73 27' Overlander and am having a new rolling chassis manufactured.
I opted for Torsion axles, so they are using Dexters. The weight rating of the new axels will be 3500 each, which is about 1,000 pounds more than my original ones. They suggested using zero degree axles.
What are your thoughts?
Brek
GuitarmanFL is offline   Reply With Quote
Old 03-22-2016, 04:53 PM   #2
1988 29' Excella
Plant City , Florida
A lot of axle threads on the forum check them out . I went with 22.5 down angle .
wjcwill is offline   Reply With Quote
Old 03-25-2016, 10:37 AM   #3
1972 27' Overlander
1971 31' Sovereign
Orlando , Florida
Hey WJCwill:
Yep. Thanks. I called A/S and they were great. Not only did they confirm 22.5 degree down angle, but felt the upgrade to 3500 pound axles would be fine. I also called Dexter and they confirmed they can make the 22.5 degree axles AND that I should also request they add the "shock kit", which they still offer. "It'll make a huge difference to your A/S". I talked to a guy in the Warranty and Service dept, FWIW.
All in all, I now feel really good about the new rolling chassis. The manufacture was going to build it with a zero degree torsion set up and no shocks.
Didn't cost me much more, and now it should, as long as all goes as planned, it should tow like a dream!
Brek
Brek D - Orlando, FL
330 watts Renogy solar
Natures Head Composting Toilet
2018 - 7,500 miles Orlando > Huntsville > OK City > Sante Fe > Durango > Gallop > Sedona > Orlando
Old 03-25-2016, 08:20 PM   #4
1988 29' Excella
I also went with 3500 # axles on 29' excella there are other options Inland rv suggests 33 degree down angle and their axles come with 12 in. brakes I believe. My Dexter 3500# axles came with 10in. brakes i'm happy with mine
Joe
Dual A/C still not enough in 90 degrees, sun, wind, humidity? Jammer Furnaces, Heaters, Fireplaces & Air Conditioning 30 06-17-2014 12:07 PM
rolling, rolling, rolling........ Isuzusweet Classic Motorhomes 1 10-07-2012 05:28 PM
- 26 Degrees | Everything is fine nunya001 Winter Living 32 05-03-2009 11:13 PM
Frig at 72 degrees, needs to be level ??? wagnerda Refrigerators 18 01-20-2008 05:00 PM
Sweet 16 (degrees) and all's (mostly) well Antique Pedaler Our Community 1 03-04-2007 09:56 PM
