Old 04-08-2016, 11:58 AM   #1
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Is this dent a problem?
I got under my 2016 FC 25' for the first time to really take a good look today, and noticed that the back axle seems to bow up in the middle, and the front axle has this dent in the middle (see picture). Is this a problem?
SeaLevel is offline   Reply With Quote
Old 04-08-2016, 12:01 PM   #2
Echelon73's Avatar
2010 30' Flying Cloud
Mocksville , North Carolina
Mine has that as well. I think it is part of the design.
Echelon73 is offline   Reply With Quote
Old 04-08-2016, 12:18 PM   #3
2007 22' International CCD
The axles are bent at the factory to align the wheels. The curve is a result. That said, the dent could also be the result of jacking up the trailer incorrectly. If your wheels seem to be aligned ok, it's not a worry
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 04-08-2016, 12:18 PM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
That is how the axle's camber is set. Nothing wrong here.
Old 04-09-2016, 11:02 AM   #5
1987 32' Excella
1999 33' Land Yacht
Clear Lake , Minnesota
axel dents
Not a problem if you don't look there!
Devananda-E9 is offline   Reply With Quote
Old 04-09-2016, 11:34 AM   #6
runnersg's Avatar
2016 27' Eddie Bauer
TX , Texas
I love these answers. ha.
As others have said, their's has it too. Mine is a 2016 and it is also there.
2016 Eddie Bauer 27'
runnersg is offline   Reply With Quote
Old 04-09-2016, 12:07 PM   #7
1989 32' Excella
Sharon Springs , New York
Very interesting as my 1989 Excella doesn't have a dent in the middle of either axle. In fact, neither axle tube has any damage at all. I wonder if this apparently "new" technique in axle construction is an improvement or just a quicker way of "adjusting" the axle to required specs. I would think that a non-reinforced "dent" would be a weaker area as the metal has been stretched (unless it is a formed dimple). Just hope it doesn't become a future issue, any additional info on this would be appreciated. Good luck and travel safe.
JDB
MAJORJDB is offline   Reply With Quote
Old 04-09-2016, 12:45 PM   #8
dznf0g's Avatar
Oswego , Illinois
Normal
-Rich-
Old 04-09-2016, 12:54 PM   #9
This is the alignment process for torsion axles.
http://inlandrv.com/tours/axle-plant/5-aligner.jpg
Old 04-10-2016, 08:06 AM   #10
1996 25' Excella
Tillsonburg , Ontario
A dent in the middle of the axle has no bearing on strength. The load is carried at the frame where the axles are mounted.
JCW
JCWDCW is offline   Reply With Quote
Old 04-14-2016, 09:21 PM   #11
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
ALL axles have an upward arch in the middle. This sets castor/camber to help pull straight without fish-tailing. Some people will "flip" the axles on leaf spring setups for more clearance. This puts the arch downwards and will cause your tires to wear prematurely.
AlbertaBound is offline   Reply With Quote
Dent Removal uwe Ribs, Skins & Rivets 11 01-17-2016 01:48 PM
Condensation problem...big problem MonaxLisa General Repair Forum 16 10-31-2010 10:00 PM
Dent Pullers wagsrp Ribs, Skins & Rivets 12 07-30-2009 07:14 AM
Battery problem or converter problem Paul Daugherty Airstream Motorhome Forums 31 07-01-2003 06:16 PM
Dent Repair Jim W Ribs, Skins & Rivets 3 05-07-2002 11:43 AM
