09-26-2017, 10:11 PM
1961 24' Tradewind
Ventura
Is this a broken leaf spring?
My 1961 Tradewind 24 has been home two days now. I decided to really look at her and do an restoration assessment. Well, looking under the axle I saw what I think is a broken leaf spring. The other side is fine. Experts....what is it?
09-26-2017, 10:25 PM
1979 23' Safari
1954 29' Liner
Orange
Looks like a skid plate to keep the brake drum from dragging on the ground in the event of a tire failure.
Bill
Originally Posted by martymcclain
My 1961 Tradewind 24 has been home two days now. I decided to really look at her and do an restoration assessment. Well, looking under the axle I saw what I think is a broken leaf spring. The other side is fine. Experts....what is it? Attachment 295647Attachment 295648
Just my personal opinion
https://billbethsblog.blogspot.com/
09-27-2017, 10:12 AM
1973 21' Globetrotter
Houston
These things were optional equipment back in the day. They were called something like a "tire saver," and the idea was that if your tire goes flat, they drag on the pavement and keep the rim from cutting the tire, and the cut tire from destroying your wheel-well.
09-27-2017, 07:08 PM
1961 24' Tradewind
Ventura
Well you solved that mystery. There is only one though and I couldn't have leaf springs, there are shocks on each tire. This being a 1961, do you reccomend replacing axle?
09-27-2017, 09:03 PM
Moderator dude
1966 26' Overlander
Phoenix
1961 is around when the transition took place for Airstream from leaf springs to torsion springs. If they are early torsion springs the axles are welded in.
With either spring type if they are original they should be replaced. Neither spring type lasts forever. Leaf spring axle ONLY needs the leaf spring to be replaced. The axle would still be good assuming the spindles are good.
Torsion spring axle would require the entire assembly to be replaced because the spring is internal to the axle assembly and is not serviceable. Torsion springs have ride qualities that are very beneficial over leaf springs. However torsion springs have a shorter service life than leaf springs.
Removing a torsion axle from that vintage is a chore as it needs to be cut out and the new axle welded in. Leaf springs will be very easy to replace as a comparison.
And thinking about converting??? (either direction) Anything is possible with enough money and time. The easier and less spendy method would be to replace same for same.
Good luck with your new toy.
>>>>>>>>>>>>>>>>Action
09-28-2017, 11:51 AM
1961 24' Tradewind
Ventura
Thank you for the info guys...
Marty
09-28-2017, 01:31 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
You can see in your picture that you have a tortion axle.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
