Old 01-12-2003, 03:00 PM   #1
Jason1101's Avatar
Is a bent axle a "dead" axle??
When checking out my "new" '76 Sovereign before purchase, I noticed one of the axles is bent "up" in the center. (To within 2-3" of the belly if memory serves me) The torsion arms still have plenty of negative angle and both look similarly loaded on each side.
Will the bent axle funtion as originally designed? Can it/should it be rebuilt/straightened?
We're not planning on major travel with the new AS, just to and from the hunting club 100 miles each way once a year. This is NOT to imply I want to shirk any safety responsibilities, this is just for a frame of reference.
Thanks for any input!
Jason
Jason1101 is offline   Reply With Quote
Old 01-12-2003, 03:12 PM   #2
Chas's Avatar
Images: 22
I have noticed the same thing on my Overlander which has good axles as far as I have been able to discern. I have seen bad axles with the same upward bend in the tube so I really don't know what causes it. It could be that way from the factory to get the necessary camber degree ? Any other ideas?
Chas
Chas is offline   Reply With Quote
Old 01-12-2003, 04:54 PM   #3
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
It's Normal
But, did you say only 1 of the axles have a bend? Below is a picture of a new axle, with a 2X4 across the bottom. I measured the gap at 5/16". The board was not quite the length of the entire axle, so that measurment may not be entirely accurate.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 01-12-2003, 05:03 PM   #4
Jason1101's Avatar
Unfortunately, she's about an hour away or I'd post a photo. I'll have to look again to confirm, but Yes as far as I can remember. Only one is noticebly bent up.
Thanks!
Jason
Old 01-12-2003, 05:24 PM   #5
striker's Avatar
Images: 14
Lightbulb 2x4
the 2x4 your using to check the axel is it straight?
striker is offline   Reply With Quote
Old 01-12-2003, 07:07 PM   #6
JPAIRSTREAM's Avatar
1972 31' Sovereign
, Ohio
Images: 47
Yes they are all bent up at the center like that.. brand new or old..
JP
JPAIRSTREAM is offline   Reply With Quote
Old 01-13-2003, 09:00 AM   #7
hex
hex's Avatar
WHY ??
hex is offline   Reply With Quote
Old 01-13-2003, 10:10 AM   #8
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Bend in axle
The bend sets the camber of the tires. Camber is the angle of the axle shaft to the ground. The axles have a positive camber.
John W. Irwin
WBCCI #9632
Old 01-13-2003, 01:50 PM   #9
Jason1101's Avatar
Makes sense! I'll have to look again but I only remember one being noticeably bent, although the other may have been slightly bent. Maybe the different axles required a different bend??
I should be going back up to check on her within the next couple of weeks, and I'll try to remember to take my camera... (I'll also look at the camber of the wheels, if it's a serious problem it might even be noticable...)
Thanks again!!
Jason
Old 12-11-2007, 10:33 PM   #10
1968 26' Overlander
Stevensville/Fort Fun , Montana
Axle bent up
I have noticed the same thing on my 68 overlander. I have also seen it on many other trailers , including my boat trailer, so I think it is normal.
out4trout is offline   Reply With Quote
Old 12-11-2007, 11:10 PM   #11
A properly aligned "torsion" axle, will have the square tube bent upwards in the middle, or very close to it. That bend alters the caster camber. The correct caster camber is 3/4 degrees, plus or minus 3/4 degree. That means the bottom of the tires should be closer together than the top of the tires, from side to side of the trailer.
If the square axle tube does not have a bend, then that axle is not properly aligned.
The axle tube is also slightly bent rearward, to achieve proper "toe in." Proper toe in is 1/8 inch, plus or minus 1/8 inch. However, a zero toe in on one side and a 1/4 toe in on the other side, is not acceptable. All the toe ins should be the same, for proper tire wear.
Old 12-12-2007, 04:40 AM   #12
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
This is a very old thread but Andy's reply is dead on. However, I have never seen a 2x4 used to measure it. The 2x4 would have to be very straight. A 6 foot metal level that is really straight would be better but assumes there is no bending of the arms or spindle of the axle to mess up the chamber. A better suggestion (if no Airstream dealer were not available) would be to take the unit to a truck alignment shop that has the proper equipment to directly measure the camber using the chamber gauge which is placed directly on the rims of the tires.
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Axle Question drex Axles 7 07-30-2007 05:50 PM
Tri Axle Question HowieE Axles 30 10-27-2004 08:44 PM
Sorry. Another axle question whistler Axles 6 08-28-2004 10:33 AM
New Axle Installed. Success! DanLyle Axles 0 04-24-2003 11:00 PM
