Old 08-14-2007, 05:34 AM   #15
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by WestMichCamp
You have the same base rate as we do in Michigan. There is just a $60.00/hr surcharge in FL for the extra Sunshine.
Ah, I see.
I think it is so we can pay for these $100,000 houses that we paid $440,000 for...
Old 08-14-2007, 07:21 AM   #16
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
The modifications for aftermarket axles are quite easy with the right tools. $40/hr is a cheap labor rate and at the install price you stated I would jump all over that deal. You may want to look at some of his previous welds/work and make a judgement call. In most cases OEM parts are of better quality and I would usually go with OEM but in the case of the axles I would feel very confident with Dexter. They are probably the biggest axle supplier in the US to trailer manufacturers. Parts are widely available. I performed the axle swap myself - I figure that I added a couple of hours on to the length of the job to cut/weld the shock mounts, grind away the opening in the trailer frame and bore out two of the bolt holes in the frame.
Good Luck
crispyboy is offline   Reply With Quote
Old 08-14-2007, 07:37 AM   #17
flitzwhopper's Avatar
1976 Argosy 24
Tempe , Arizona
The power of DUH
at the risk of drawing the wrath of the professional engineers who contribute to the knowledge base here, isn't it reasonable for a vintage owner who is unsure of the ride in their camper to have a friend with a late model let them ride down a rough road in their camper and then compare it to their own? Isn't ride the real issue?
It seems to me that there are all sorts of variables that determine the rate of deterioration of the materials in the axels. A light camper with dual axels that has low milage and lived in a moderate climate may be different than a 31 footer that has 100k miles and has lived in Phoenix.
Donna & Mike
Cowboy up! or go sit in the truck
Charter Member Four Corners Unit
WBCCI #2417
flitzwhopper is offline   Reply With Quote
Old 08-14-2007, 07:53 AM   #18
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Also the amount of just plain sit time has an effect. I thought that plain old sitting has a negative effect. The axles need to move and flex to keep their trim. Much like tires. Low mileage isn't always a good thing.
Jack
Jack Canavera
STL Mo.
AIR #56
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Not an Airstream but interesting dienst1 Airstream Motorhome Forums 11 09-15-2002 11:16 PM
Very interesting story/ back pack FrankR On The Road... 2 08-31-2002 08:29 PM
Headers, Exhst, Axle Changes? Sav'h Steve On The Road... 8 08-22-2002 07:14 PM
Interesting link GMC coop ALANSD Link Archive 8 03-14-2002 01:40 PM
