Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 10-02-2009, 05:31 PM   #1
Profile:  1967 26' Overlander
Winston Salem , North Carolina
Images: 101
Installing new axle of a 67
I have finally bit the bullet and purchased new axles and brakes from Inland RV.
I have removed the rear axle and I am trying to install the new one, but there is a slight problem.
The axle will not go up in the slot all the way.
I have used a grinder a little on the slot and I am guessing the the axle is lacking 1/8" before it would be flush to the frame.
Pics are included, old axle pic is for reference.
Do I need to keep grinding the slot? If that is the correct name...
ID:	88091   Click image for larger version
ID:	88093   Click image for larger version
ID:	88095   Click image for larger version
Greg
Winston Salem, NC
WBCCI 5218, Piedmont NC Unit 161
1967 Overlander International.
FTC 15771
1979 Avion 30ft rear bath
Silverwanabe is online now   Reply With Quote
Old 10-02-2009, 05:57 PM   #2
silverleeper's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
You need to find out where it is binding. Is it in the channel? Or is it the plate on top of the axle resting on the frame? If it is the top plate then grinding out the channel will only make things worse. If I remember correctly when I put in my axle there was a small gap.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 10-02-2009, 06:34 PM   #3
Jim Foster
Jim Foster's Avatar
Profile:  1965 17' Caravel
1983 27' Excella
Walnut Grove , California
I think I remember being told by Greg at Inland that there are two sizes of square tube used on axles, and that older trailers use the smaller size and on later trailers the slots are made to accept the larger tube. Don't know for sure, but perhaps Andy can jump in.
If the axle goes up the distance, will the mounting holes line up? I think that is the key here. The flange should rest against the frame, and the mounting holes match up. Otherwise, you may have no idea where the axle should be.
Jim Foster is online now   Reply With Quote
Straight Axle vs Drop Axle Sound off. soldiermedic Axles 12 03-24-2009 07:39 AM
Installing a new Dexter Axle Alumanutz Axles 23 08-21-2008 10:55 PM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 11:37 PM
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 05:15 AM
