Old 08-16-2008, 03:58 AM   #15
Originally Posted by Mexray View Post
Sorry...I missed that you have a 66 AS.... and have to drill new mounting holes...
You have the added burden of drilling the holes in the same spot on each side...measure twice and drill once as they say....
Regards,
Ray
Not true.
It doesn't matter where the holes are drilled, just so that there are 3 on each side, from a968 and older.
The square slots align the axles.
Old 08-16-2008, 09:16 AM   #16
Alumanutz's Avatar
1966 22' Safari
Chico , California
Andy, the original axle only had two bolts. Does the Dexter need three for a reason?
Alumanutz is offline   Reply With Quote
Old 08-16-2008, 11:43 AM   #17
Originally Posted by Inland RV Center, In View Post
Not true.
Correction.
That year should say 1968 and older.
Old 08-16-2008, 11:44 AM   #18
I have no idea how many bolts must be used on a Dexter replacement for 1968 and older Airstreams.
Old 08-16-2008, 12:53 PM   #19
Somewhere , Indiana
Two!
The Dexter mounts with two holes, as seen here:
http://i.b5z.net/i/u/1080235/f/Torfl...ation_4-04.pdf
I could not find a drawing on the GKN website to check that mounting bracket. I did however find this:
http://www.gknaxles.com/images/press...ER-MAY2008.pdf
Some pretty interesting reading!
Andy is correct about the square slots assuring alignment!
Best Regards,
Henry
axleman is offline   Reply With Quote
Old 08-18-2008, 01:07 PM   #20
Alumanutz's Avatar
1966 22' Safari
Chico , California
I don't wish to be a PITA but I am not getting the three bolts thing. Here are the photos of my original axle and the mount on the safari (1966). Did the factory mess up? I only have two. Anybody need an old axle or should I saw this bugger in half and post the pictures of the inside of this thing?
NUTZ
ID:	65843   Click image for larger version
Name:	Trailer mount.JPG
Old 08-18-2008, 01:22 PM   #21
NUTZ
As I understand it, the holes in the Dexter should line up with the axle mounting plate.
If they do not, then raise the axle in place, drill 3 each 1/2 inch holes, thru the axle mounting bracket and thru the axle mounting plate. Duplicate that for the other side.
Install the 1/2 inch grade 8 hardware, that should of been supplied, along with installation instructions from whoever you purchased the axle from.
Old 08-18-2008, 02:30 PM   #22
Central , Mississippi
New Holes
Here's how I did it. Start at post 147 and it shows how I matched the axle to the holes that were already in the trailer.
http://www.airforums.com/forums/f437...-39688-11.html
Good Luck!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-19-2008, 06:51 AM   #23
dnrtheil's Avatar
1964 24' Tradewind
Portage , Michigan
Hey Alumanutz, my new Dexter has only two bolts per side, the original axle on my 1964 only had two bolts per side.
Derek
Operation "SAVE RUDY" Strike Team (Associate Member)
dnrtheil is offline   Reply With Quote
Old 08-21-2008, 09:55 PM   #24
Alumanutz's Avatar
1966 22' Safari
Chico , California
Tired, dirty but done. A few snags but nothing a plasma cutter did not take care of!! Doorgunner, here we come!
NUTZ
Dexter axle installation Inland RV Center, In Axles 22 09-20-2013 04:27 PM
Axle replacement - Dexter #10 w Disc brakes vs original FrenchBern Axles 27 05-22-2008 11:23 AM
Dexter Direct Bolt In Axle bikrmikey Axles 28 07-29-2006 10:16 AM
Dexter Axle Installation Started! Streamin 65 Axles 17 06-07-2006 04:02 PM
Dexter vs Henschen Ericjeeper Axles 38 03-31-2005 11:16 AM
