Old 05-21-2013, 06:00 PM   #1
1982 34' Limited
Harrowsmith , Ontario
Installed the new axles
Over the long weekend, I finally was able to install the axles that I ordered from Colin Hyde in February. I just have to say it was a whole lot easier than I thought it would be! The only issue I had was one bolt on the original rear axle that would not loosen - I eventually cut it off which I wish I had done an hour earlier before bothering to heat it etc - not sure what the deal was but my impact gun couldn't budge it.
Once I got the each old axle out (which apart from the stuck bolt only took half an hour) it was only a few minutes to get the new one in - everything lined up and no new holes had to be drilled.
I did it all by myself with the exception of moving the first one out of the garage which my wife helped me with, the second I decided I could handle myself. If you had a helped you could do it in less time.
So congratulations to Colin and Axis for making the job so simple. I'm impressed.
BradB is offline   Reply With Quote
Old 05-21-2013, 06:54 PM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
...didn't happen without pictures.
just sayin'
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-21-2013, 06:56 PM   #3
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
And a picture of yourself holding a spoon.. so we know it is really you.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 05-22-2013, 06:12 AM   #4
1982 34' Limited
Actually I haven't taken any so far but I'm in the process of changing the tires as well so I'll grab some tonight. The old ones are still beside the trailer while I figure out what to do with them.
I thought about taking pictures and then figured "who wants to see pictures of axles" - guess I was wrong!
Old 05-22-2013, 12:18 PM   #5
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
I'm glad to hear your swap went well. Mine? Not so much. The shock brackets were shipped separately and required us to hire someone with a MIG welder to weld them in place. We could not have done this swap by ourselves.
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 05-23-2013, 09:23 AM   #6
1982 34' Limited
Sorry to hear that - which axles did you get?
Old 05-24-2013, 06:56 AM   #7
1982 34' Limited
Pictures
Here are some pictures of the new axles in place as well as the nasty old ones.
ID:	186451   Click image for larger version
Old 07-27-2013, 04:30 PM   #8
thomdial's Avatar
1979 23' Safari
, Ohio
Eljay,
I'm about to buy axles for my Safari. I really don't want to go through the hassle of welding on shock brackets. Would you mind giving me an idea of where yours came from?
thanks
thom
thomdial is offline   Reply With Quote
