Old 07-03-2008, 03:17 AM   #1
1978 25' Tradewind
Louisville , Colorado
Increase Ground Clearance
I have a 78 Tradewind ( 25 ft) My wife and I like to get away and take the trailer dry camping off the main road on dirt roads. I have been beating up the belly pan pretty badly, not to mention scraping the bottom several times.
Does anyone know how to increase the ground clearance on this trailer?
I heard something about rotating the axles... anyone?
twilight10 is offline   Reply With Quote
Old 07-03-2008, 04:02 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Welcome to the forums. Nice looking Trade Wind, I have a 75.
Your axles look a little low, but you must be going down some rough roads to scrape the pan. I have never done that and I travel a lot of dirt roads. There are no adjustments to these axles. Flipping them is not an option on this type of axle, but I have seen it done on some leaf spring type trailers, mostly pop ups. You could replace them with new and specify a greater angle on the arms. That would cost some bucks, but give you several more inches of clearance.
Richard
Old 07-03-2008, 06:54 AM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Welcome from Arvada. As AZflycaster has said above, the only way to increase ground clearance on a torsion axle is to replace it with either a greater angle of deflection on the swing arm, or with a taller profile on the mounting angles, which also is an axle change. My axle was shot and I gained 4 inches with a new one. I ordered it from Redneck Trailer in Firestone, They are the area dealer for Dexter Axles and were very good to deal with.
Old 07-03-2008, 09:12 AM   #4
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
It definitely sounds like it could be the axles. I had excellent service and reasonable pricing when I had mine replaced at Intermountain in Colorado Springs.
Good luck!
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 07-03-2008, 10:23 AM   #5
Sound like your axles are shot.
The following article will help you check them out yourself.
Dura Torque Axle
Henschen axles were the original equipment. Other brands are available with some associated problems.
1. You must provide all the specs.
2. If your specs are wrong, you eat it.
3. They will not build a 35 degree starting angle.
4. There are only 3 ratings available from them. In your case, way under, way over and way way too much.
5.They will only supply 10 inch brakes.
On the other hand, we only need your trailer serial number for proper identification.
You now have 2600 pound axles, that we can change to 3000 pounds, no more.
We provide the axles with 12 inch brakes
We provide a maximum starting angle approved by Airstream and Henschen.
You cannot, as you asked, rotate axles. That is not the problem. The problem is with the rubber rods, as they have given out and/or solidified.
In either case, the trailer is bottoming out, which will cause all kinds of damages, that get to be expensive, quickly.
Old 07-03-2008, 11:42 AM   #6
I forgot to mention two things earlier:
Mine sat up higher off the ground after the axle replacement, and.....Andy is the BEST one to get advice and the axles from. He has great service!!
Old 07-03-2008, 12:07 PM   #7
bedfords's Avatar
1975 29' Ambassador
Littleton , Colorado
Welcome to the forum! Great to have another CO in the crowd.
You have a great looking trailer.
Master of the Tin-Can
and thats not saying much
bedfords is offline   Reply With Quote
Old 07-03-2008, 10:24 PM   #8
1978 25' Tradewind
Thank you for all your kind help
Twilight
ground clearance
Mud flap ground clearance? hazegrey Hitches, Couplers & Balls 4 10-31-2007 08:42 PM
Raise ground clearance on 25', '91 Excella? ldetsf Axles 11 10-18-2006 06:29 PM
What should the ground clearance be? 63air Towing, Tow Vehicles & Hitches 4 07-19-2006 01:01 PM
ground clearance/battery charge Kintscher Our Community 14 06-01-2005 03:36 PM
how much ground clearance? Chuck Plumbing - Systems & Fixtures 1 05-26-2004 10:10 AM
