Old 03-19-2016, 09:47 PM   #15
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
Inland RV installed 4500lb axles on my 77 31' that also weighs 7500lbs in 2010. The new axles raised the trailer about 4 inches and after 6 years have not dropped hardly at all. The ride is smooth.
4RXLA is offline   Reply With Quote
Old 03-20-2016, 06:02 AM   #16
KYAirstream's Avatar
Northeastern , Kentucky
So I take it 7500lbs is fully loaded with water, propane, and all supplies? That's a 1500lb margin with the 9000lb rating. Glad to hear the ride is still smooth.
How is the ride if you pack lighter? Do you have to be careful going too light since there's such a large margin?
KYAirstream is offline   Reply With Quote
Old 03-20-2016, 07:38 AM   #17
larry b's Avatar
1975 31' Sovereign
howell , Michigan
1975 31' rear bedroom had 3200lb original axles replaced in 2011 with 3600lb and 16" wheels very pleased with the ride. I used axis axles and was able to order direct, I have heard they no longer let you order direct.
Not sure if others do this,when trailer is not in use, I take the weight of the axles, Jack stands.
larry b is offline   Reply With Quote
Old 03-20-2016, 08:32 AM   #18
4RXLA's Avatar
Images: 33
The 7500lb weight is unloaded. I'm probably closer to 8000lb fully loaded with water and propane tanks full. Old stiff axles will shake up your trailer much faster than newer ones with a higher weight rating.
Old 03-26-2016, 07:07 AM   #19
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I replaced the 4,000-lb axles on my 32-ft Excella with 4,500-lb ones - this was done at JC. Included were new 16-inch rims and Michelin LTX load range tires. Last year I had the whole rig/TV weighed when I was at the Escapade in Tucson. With all holding tanks full, I came in under the max weight ratings.
http://www.vsquare.com/howard/photos...smartweigh.pdf
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 03-26-2016, 08:13 AM   #20
Thanks for sharing that data sheet! So you're coming in at 8750lb with 4500lb rated axles, so it sounds like 4000lb rated axles would be more than enough margin for my trailer at 7500lb when loaded, with some room to spare.
If your trailer isn't packed full, do you have any concerns about the ride being too stiff?
Old 03-26-2016, 08:20 AM   #21
Although your under a 15% bump in capacity, whereas a 15% bump in capacity for me puts my 3200lb axles at 3680lbs.
Did Airstream realize over the years that 3200lb rated axles were under capacity for a 31 ft trailer? While your excella is heavier than mine, it doesn't seem to be that much heavier, so it makes me wonder if my 3200lb axles were marginal from the onset?
Old 03-26-2016, 09:06 AM   #22
4RXLA's Avatar
Images: 33
Seems to me like Airstream subtracted the tongue weight and let the axles cover the rest. I prefer the axles rated high enough to cover the entire weight of the trailer plus gear and fluids.
Old 03-26-2016, 09:14 AM   #23
4RXLA's Avatar
Images: 33
Name:	ImageUploadedByAirstream Forums1459005193.823630.jpg
ID:	259377Here is what my trailer weighed in 2008 while still mothballed and mostly empty.
Old 03-26-2016, 10:24 AM   #24
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Many trailer manufacturers will equip it in a manner that just covers the load with little to no margin. It keeps the costs down while competing for market share. Most buyers are not that educated and are looking at the shiney!!! The goal is camping not necessarily how one gets to the camp site.
>>>>>>>>Action
Old 03-26-2016, 03:02 PM   #25
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
One must keep in mind.
Tongue weight is not carried by the axles.
The GVWR includes the weight of the axles and hardware including tires. The axles do not have to carry their weight. Only the weight of the coach and whatever is loaded.
If one has a coach with a 7,500# GVW. You could probably subtract a 750-900# tongue weight in addition to 400# or so of axle, tires etc.. Using the max weights of 900+400=1,300. Subtract that from the 7,500-1,300=6,200. Two 3,500# axles gives you 800# buffer.
Old 03-26-2016, 03:37 PM   #26
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
The ride is fine. I do have Centramatics which ensures that the wheel/hub/brake/tire assembly is dynamically balanced making for a smooth ride. Tires are inflated to 80 psi.
VE3JDZ
AIR 12148
Old 03-26-2016, 04:58 PM   #27
3200 pound axles for an average owner of a 31 foot Airstream (Old Excellas excepted) is fairly OK.
But, todays owners carry far more things, and stay on the road for longer periods of time.
Accordingly, the axle rating can be increased to 3500 pounds for the seldom users. Increasing to 4000 pounds is OK, BUT , the payload must also be increased, along with having the running gear absolutely balanced.
Part of that payload is full water. Total water weight for the later trailers, bumps 400 pounds. 50 gallons fresh, and 6 to 10 gallon water heaters, plus whats in the water lines.
Then add to that, at least a half tank of gray water and a half tank of black water, just to be safe.
Increasing axles from 3200 pounds to 4000 pounds REQUIRES that more attention be given to proper loading as well.
As an example, if 3200 pound axles are increased to 4000 pounds, and the trailer is towed with empty tanks and a light pay load, the ride will be much harsher than if loaded adequately.
The heavier the axle rating, the heavier the payload MUST BE. If not then damages will occur.
When replacing the older torsion axles, keep in mind the way you typically load the trailer, so that you can discuss your requirements with whom ever you choose to purchase axles from.
Axle ratings do not change the costs, but excessive ratings not using will certainly create repair bills.
Airstreams MUST HAVE a soft ride. Loading torsion axles correctly will provide that soft ride.
Old 03-27-2016, 07:08 PM   #28
Increase axle rating on 1979?
Thanks for the replies.
Just to reiterate, carrying ZERO supplies and only full water and propane, per the CAT scales the trailer weighs in at 6660lbs with 660lbs tongue weight. If we can assume a deduction of 1060lbs (400 for axles and 660 for tongue weight), then each axle is carrying roughly 2800lbs.
When loaded with a weeks worth of supplies, the CAT scales show a trailer weight of 7500lbs with a tongue weight of 750lbs. A deduction of 1150lbs for tongue and axle weight suggests each axle is carrying approximately 3175lbs.
Given the above, what's the best axle rating to accommodate being fully loaded with supplies to last a week, as well as being loaded lighter for a weekend trip?
IF the assumption regarding axle weight is correct (approx 400lbs, or 200lbs each), then it seems like 3500lb rated axles would be plenty.
New axle capacity increase bicen.falcon Axles 3 07-14-2015 07:50 AM
Axle Rating RichardT 1961 - 1963 Bambi 53 12-23-2005 08:21 AM
'71 GT Axle Replacement/rating LarryD Axles 5 03-29-2005 03:23 PM
Axle rating dmadam Axles 1 10-08-2004 12:52 PM
'69 Ambassador-Org. axle rating 1stimer Axles 4 11-24-2003 10:58 PM
