i want to build a concession trailer out of a globetrotter. with all that extra weight, i would want the safety of a dual axle. how realistic is this?
i was thinking: cut off the original axle, which is semi centered, then modify the wheel wheel inside and out, then weld in a dually set up. would i offset the dual set up toward the back? and is the original framing beefy enough for the extra weight? are there certian year globetrotters with beefier framing? early 60's preferred or 50's if i was blessed enough to find one i could afford. and of course i'm looking for pre gutted or super trashed interior. we would never gut a complete, good condition, 50's airstream! rescue airstream, if you will.
is there any photos of concession trailers floating around?. thought i remember one in a vintage trailer book i lent out.
thanks
Yes, there are a number of these. I'd recommend a close look at the GAWR on single trailers. Honestly, all the work you're talking about could be cut in a fraction by buying a double axle trailer to begin with. Then if you're talking big miles to go to festivals and fairs, put your money into a pair of new Dexters or Henschens.
__________________ . BobStream
...You really don't know someone 'til you've had recess with them. ...Alex Ziton, age 8
the idea was to stay under 20'. dual axle usually means 23+ and keep the vintage look. i think streamline or silver streak made a shorty with a dual axle but its the darn anodized aluminum. which has its advantages, but we definatly want the mirror shine.
Is the dual axle just for weight? I think you can get a new axle with a heavier rating that might suit your needs.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529 http://northvancouvermodern.blogspot.com/ Live! Life's a banquet and most poor suckers are starving to death! - Mame Dennis
well that was the first thing i though BUT i just thought it would be a bit safer on the highway if with all the extra weight, one got a flat. how does your bigger single axle airstreams react loaded down when you get a flat?? i know i popped a leaf spring on a single axle 16' trailer loaded down and i thought we were going to die for sure! (we didnt.) i dont mean to fear monger and i'm a fan of the single axle look on vintage airstreams, i just want to properly accomodate the weight, with a certian look and size that is also an airstream.
Converting a single axle to a tandem, is not that difficult, especially since your going to gut the trailer to start with.
You need to come up with the total weight of everything that you wish to install in the trailer.
You also need to make a layout drawing to make sure that you will keep a reasonable weight and balance along with a tongue weight.
Your absolutely correct about the hazards of a single axle. You get a flat, provided it's not a blow out, and your sort of done. With a tandem, you can stop, remove the flat, and then slowly continue, or, carry a spare.
There are many advantages to a tandem, beginning with stability, and vertical stability.
We have made several such conversions, over the course of years.
You can outfit the trailer, using 2 axles, from as little as 4,000 pounds, to as much as 10,000 pounds.
thats good to hear, especially coming from someone who has done it. lets assume all of the equipment inside is evenly placed weight-wise front to back, would i want to center the 2 axles? i noticed on most tandems, they are offset toward the back. i would think that would give you more tongue weight, but less sway on the road?
i would imagine that the offset is not great enough where i could keep the existing part of the front of the wheel well (and existing axle placement), then 'add' an axle behind it, cutting only the back half of the wheel well.?
Some Safaris came with dual axles and is only a couple of feet longer than the Globetrotter.
Kai & Samm
North Vancouver, BC
Canada
And lots of Tradewinds came with single axles. . .
I think you'd better follow Andy's advice. I don't think you will be able to just add another axle to the rear of the original. Best case, you would center both new axles an equal distance forward and aft of the where the original was. Better to make a balance diagram and have someone calculate the moments and tongue weight, based on the equipment you will be adding. Don't look for shortcuts, you could end up with an awkward and ill-behaved spawn of satan.
It doesn't ever work out that way.
It doesn't work that way either.
You are asking for a complete redesign.
Guess work will blow the deal.
Homework, and lots of it, along with drawings locating each piece of equipment, along with it's empty and loaded weights, as an example an ice machine or cooler, empty and full, cooking equipment, refrigeration, storage location, LPG tanks and sizes, generator (if used), water tanks and capacity, gray water tank and capactity, water heater, furnace, air conditioner, serving window location and size, and the list goes on and on.
Guess work and assumptions, will allow you to spend lots of money and more than likely giving you a trailer that would be unsafe to tow, at any speed.
Since we have done this before, we assure you, do the homework and drawings.
Or, have someone do it for you, that has the knowledge and experience for such a task.
thanks andy,
would love to have Inland do it, but your too darn far away. although my dog wouldnt mind another trip your way for those sweet Hawaiin dog treats. unless of course there is a Northern Cal addition of Inland.
since i dont weld, i wont be doing the work either. but i would like to understand why tandems are offset slightly to the back. i would imagine, its to accomodate the holding tanks in the back and bath and shower etc. BUT hypothetically, if everything (all equiptment placed just so it is actually balanced) would you want the tandem set up dead center? and if the equiptment were not able to be balanced, one would arrange the heavier stuff toward the back and offset the tandem center toward the load? or would you put the heavy stuff right over the axles and center or over the axles and off center?
Just another observation for buying a tandem to start with... the mid 70's safaris are less than 23' long (mine measures 22' 5" from front of receiver to back of bumper). You will still need to be careful on the equipment installation to keep things balenced and watch the tougne weight. It would keep down cost and simplify your conversion.
