Old 08-26-2013, 06:39 PM   #1
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
I thought my new axles were bent!!!
I had a new Dexter axle installed on Friday, drove it home (about 40 miles) and parked it. This afternoon, Monday, I crawled under the trailer to marvel at my new axle and found that it was bent! I'm ticked! The idiot that installed it evidently used the axle as a jack point.
I won't accept this, but my main question for now is it safe to tow? I have two trips planned in the next 4 weeks - one about 500 miles round trip and one about 200 miles round trip, all on Interstate highways and some well paved state routes. A replacement will take at least 4 weeks, more if I get into a p-ing match with the RV outfit that did the job (I'm not afraid of that) Is it safe? It certainly won't last 20 years safely will it?
Here's a pic.
Name:	Bent axle 8_26_2013 445 pm.jpg
DryFly is offline   Reply With Quote
Old 08-26-2013, 06:42 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Here's a pic.
Umm...they're supposed to be that way...
Old 08-26-2013, 06:45 PM   #3
jump's Avatar
2013 30' International
lubbock , Texas
I am not 100% sure about this , but I recall another thread on this same issue ... You might do a search on "bent axles" ... If I recall, that bend is supposed to be there.
Someone who actually knows, will surely chime in, so you might wait to fire the first volley till you know for certain
jump is offline   Reply With Quote
Old 08-26-2013, 06:51 PM   #4
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
If that bend is in the middle, that is how torsion axles are manufactured. The angle of the bend is selected to provide the proper camber.
Ken
Old 08-26-2013, 06:53 PM   #5
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Dryfly
The Dexter axle I put on has a factory bend (center) in it.
Tim
Beaker63 is offline   Reply With Quote
Old 08-26-2013, 06:54 PM   #6
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Bow not bend he is right it is bent and it looks as though it was done by a jack! The bow is spread over the length of the axle not left of center and I am sure he saw the bow before installation and knew that it did not look like that! Good luck on the service confrontation I usually lose my patients and the laws forcemeat arm get involved!
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 08-26-2013, 06:56 PM   #7
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Read about the bend here Trailer Axle information / how to
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 08-26-2013, 07:07 PM   #8
DryFly's Avatar
1972 Argosy 20
The bend is not in the center, but about 1' off to the driver's side. If you look at the photo, you can see where a jack was placed under the axle and it bent the axle, and the steel is deformed.
Old 08-26-2013, 07:10 PM   #9
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Without that bend, the wheels would have no camber. It's a design feature.
robert claus is offline   Reply With Quote
Old 08-26-2013, 07:43 PM   #10
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
That is definitely not right. I would think the tire on that side will wear bad.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Old 08-26-2013, 07:51 PM   #11
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
That doesn't look like a normal bend or what I would term a curve. That looks like a bend and a twist. The picture is dark but it certainly looks not like a curve but more like an abrupt bend.
You can probably get it fixed with an alignment if it is bent. We had our trailer aligned 2 years ago to correct a wear problem with a stock set of Henschen axles I installed when we first got our trailer.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 08-26-2013, 08:32 PM   #12
nilesrob's Avatar
Marietta , Georgia
Images: 12
Well, this piqued my interest and I had to look at my own axles. While ours have a slight bend at the center they don't look like yours - that is not right, although I don't pretend to understand the implications, sorry.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 08-26-2013, 08:38 PM   #13
Phoenix , Arizona
If it was in the center and both axles were the same then it is probably the factory bend. If it is off center, even if it was done at the factory, it is "NOT" correct. The bow is designed to allow for the flex in the axle when the weight is put on it. The amount of bow varies for the weight and the distance between the mount and the hub face (also varies by wheel offset). The heavier the axle, the less distance you can have between the mount and the hub face because that is leverage against the axle.
M2HB is offline   Reply With Quote
Old 08-26-2013, 09:18 PM   #14
Here's a pic.
Dexter axles are bent to align them.
That bend can be in the middle or to one side.
The only way you can check for damage, is to check the alignment.
There should be a small tow in and there should also be a slight camber, which means the top of the tire should stick out a little further than the bottom.
The toe in means that the front of the tires should be slightly pointed inward.
New Axles in Austin or Dallas P&K Axles 4 09-11-2011 09:31 AM
Need axles. Inland RV Center, In Commercial Listings 0 08-01-2011 10:17 AM
Henschen replacment axles JDL Axles 14 02-04-2011 01:41 AM
