10-07-2013, 11:17 AM
#21
1972 Argosy 20
Snoqualmie
Well, the sky is not falling. I did crawl under the trailer with a tape and straight edge and determined that the bend is in the approximate center of the axle. I then called Dexter and found that indeed this bend is put in the axle after assembly to achieve a proper camber.
Thank you all for your responses, but I'm embarrassed for not having done my research before reacting so precipitously. Mea Culpa
10-07-2013, 11:31 AM
#22
1984 34' International
Toronto
, Ontario
I'd be embarrassed to admit how many times I've done just the same. Glad it all worked out in the end.
10-07-2013, 11:33 AM
#23
Port Orchard
Hey, No need to be embarrassed. You learned something new and valuable about your trailer. What you saw didn't look right so you took the appropriate action by checking it out here and elsewhere. There is from time to time some inaccurate information disseminated here (maybe even by me)(I doubt that part though), so always check it all out. I'm glad all is well.
Ken
10-14-2013, 01:22 PM
#24
Moderator dude
1966 26' Overlander
Phoenix
Based on the discovery I have changed the name of this thread.
>>>>>>>Action
10-30-2021, 05:58 PM
#25
2019 25' International
Rutherfordton
, North Carolina
Just did a pre-PDI on my 2019 25' Signature RB. Saw the same thing and was pissed. Then I looked under a brand new flying Cloud and the axles had the same bow in the middle. What a relief.
10-30-2021, 06:49 PM
#26
2017 25' International
West Lake Hills
Valuable information in this thread. Thanks for reporting your suspicions and the conclusion.
10-30-2021, 07:20 PM
#27
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by ROBERT CROSS
It sure looks like there is a dimple right at the bend point, I have not seen an axle bend that was not concentric across the entire length. Our 63 Safari was and so is the Classic....no dimple.
Well, guess what, although the originals,('03) had no 'dimples' and were bowed.
The new ones are dimpled and bowed. I'll be damned.
Not even installed yet.😂
10-30-2021, 07:33 PM
#28
2002 19' Bambi
Lafayette
Well, guess what, although the originals,('03) had no 'dimples' and were bowed. The new ones are dimpled and bowed.
The originals were probably Henschen axles and the new ones are probably Dexter.
Tim
10-30-2021, 07:40 PM
#29
2018 30' Flying Cloud
Springfield
, Ohio
It would be a good practice for posters to calm down and not begin posts by disparaging others. I see it too many times and I cringe when I see them. Count to 10 or 1000 or whatever you need before casting stones.
2018 Flying Cloud 30RB + 2020 Silverado 2500HD Duramax/Allison
10-30-2021, 10:00 PM
#30
2002 19' Bambi
Lafayette
Huh?
This thread began in 2013 and I see no sign of any poster in subsequent years disparaging anyone. If you think I did so with my post immediately above, I certainly did not have that intent.
Tim
10-31-2021, 07:43 AM
#31
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Tim
True that...
10-31-2021, 08:15 AM
#32
Rutherfordton
, North Carolina
Is it a curve, bend, or bow?
10-31-2021, 10:13 AM
#33
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
All of the above.
Plus dimple.
Why...does it matter?
10-31-2021, 10:46 AM
#34
2019 27' International
2014 25' International
Boulder City
, Nevada
Lamar: We build trailers that last
Spring vs. Torsion Trailer Axles: What's the Big Deal?
There are some great videos of Torsion Axles on the Internet. I learned a lot. I made a copy of their comparison for reference.
There was one video where the axle was cut in the center to fit. The Rubber for the Torsion did not appear to go all the way across... either. One guy was fitting Axles to fit a flat bed trailer and was showing how to weld it, without damaging the rubber.
Human Bean
10-31-2021, 12:13 PM
#35
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
YES
The 'beam' is only there to hold the spindles apart, and to give the uninformed a place to jack the trailer. NOT 👎
ie The axles are 'aligned' on a jig during manufacture, and tweaked a bit after install if needed.
POI... I watched the tech do the measurements. Our install was well within specs, no adjustments needed.
10-31-2021, 12:25 PM
#36
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
The "cut in half" axles were used in 1980's AVION trailers. Avions have a very stout frame (8" triple I-beam) and the cut axles gave them the equivalent of an independent suspension. The jack easily works on the frame of an Avion.
10-31-2021, 01:04 PM
#37
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
AS has always touted it's 'independent' suspension.
10-31-2021, 01:07 PM
#38
2002 25' Safari
Dewey
It is my understanding that the capacity of the axle is determined by the length of the rubber rods. To increase the capacity, they use longer rods...
Richard
10-31-2021, 01:40 PM
#39
Moderator dude
1966 26' Overlander
Phoenix
My understanding as well.
There are 2 may be 3 axle tube diameters. The load capacity differences are accomplished by increasing or decreasing the length of the rubber rods.
Action
10-31-2021, 03:43 PM
#40
1987 34' Limited
Hantsport
, NS
Geez, jacking a naked 240lb axle up into place twists the tube and puts it out of alignment? I do understand not lifting the trailer using the axle as a jacking point but am surprised to hear that the axle won’t tolerate its own weight
