Old 03-17-2011, 10:20 PM   #1
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I suspect it needs axles
I haven't put hands on this trailer just yet, but looking at the pictures I'm concerned that it needs axles. It's not exactly a steal, but it's VERY original if the pictures are at all accurate. I'm concerned that the axles are original too.
It's a 1972 Overlander. The seller had it serviced when he bought it, at an Airstream service center, and they told him it didn't need new axles. I'll test the drop before I make any decisions, but am I wrong? It looks like it's sitting too low, I think there should be a bit more tire exposed if it's not heavily loaded.
Old 03-17-2011, 10:26 PM   #2
The following article will help you check out your axles.
The Dura-Torque Axle
Old 03-17-2011, 11:58 PM   #3
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
On look alone I would say it needs new axles.
4RXLA is offline   Reply With Quote
Old 03-18-2011, 07:49 AM   #4
funkill's Avatar
reno , NV
Images: 27
When was that?
It probably does need axles - but the test in the article Andy linked is a quick and easy way to determine how *shot* the axles are. Thankfully, it's a rather straight-forward job. You might use the cost of replacement as a barganining chip when negotiating the price....
Laura
funkill is offline   Reply With Quote
Old 03-18-2011, 08:15 AM   #5
DKB_SATX's Avatar
1976 Argosy 28
Originally Posted by funkill View Post
When was that?
Laura
The current owner has only had it a year or so, therefore the inspection by the Airstream authorized service center was around a year ago. I'm definitely going to go in with the price of axles in mind, in case it fails the test.
Old 03-18-2011, 08:39 AM   #6
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
It's a given....if they are original. The swap is relatively inexpensive...if the fridge is in good shape.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 04-23-2011, 06:11 PM   #7
1965 Overlander NJ
NJ_1965's Avatar
1965 26' Overlander
Hillsborough , New Jersey
I'm also going to be replacing my axles on my 1965 Overlander. Although the torsion arm is pointing slightly downward when loaded, there is not much drop in the wheels when jacked-up. My Dad bought the trailer new in September 1964. It has been in our family since then (now it's mine).
NJ_1965 is offline   Reply With Quote
Old 04-23-2011, 06:19 PM   #8
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
We checked the same stuff when I helped my friend buy this one: axles shot.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 04-23-2011, 06:23 PM   #9
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
but looking at the pictures I'm concerned that it needs axles...... , I think there should be a bit more tire exposed if it's not heavily loaded.
FWIW, I don't think you can tell a whole lot from the picture. If it had been taken level with the tire you could tell more. From above, it is all guess as to how low it is setting. You may get off easy.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 04-24-2011, 09:31 AM   #10
DKB_SATX's Avatar
1976 Argosy 28
Yeah, I went to look at the trailer in these pictures. It had lots of nice original qualities, but needed lots of things. Here's another thread where I went through it and decided it wasn't the right price for this trailer.
http://www.airforums.com/forums/f349...rth-75194.html
The trailer sat REALLY low on the axles, and the price wasn't anywhere near as low as the axles so I waited, and ended up finding an Argosy that's a little less original and a lot more functional, with fresh weatherstripping and standing tall on axles that flex nicely when you take weight off them.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | Il Progetto ó 1976 Argosy 28 Center Bath | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 04-26-2011, 05:13 PM   #11
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Ugh. So all this talk of axles, and the strange way ours bounces when its towed, and the popping rivets inside made me look more closely.. and our axles point up slightly, rather than down. No fridge, tanks empty, no gas bottles, the trailer is pretty light and empty. I started getting prices today to have it done. Sigh. But then it will be done.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 04-26-2011, 05:55 PM   #12
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Close to what ours was. And once I replaced the axles, we discovered that the one of us with the most miserable knees needed a little stool in order to get into the rig.
Lynn
WBCCI 21043
Old 04-26-2011, 06:48 PM   #13
We suggest you alter the ratings of the original axles, for more pay load, and greater ground clearance. Some place can't help you with that.
Old 04-26-2011, 07:43 PM   #14
Globie64's Avatar
Images: 18
Hey Andy, are you suggesting I can adjust the current axles?
Henschen replacment axles JDL Axles 14 02-04-2011 01:41 AM
