Old 04-26-2011, 07:44 PM   #15
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
I'm going with the 5200# axles, 12"/6 lug drums
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 04-26-2011, 07:54 PM   #16
Originally Posted by Globie64 View Post
Hey Andy, are you suggesting I can adjust the current axles?
Nope, since it can't be done.
Old 04-26-2011, 08:00 PM   #17
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
I'm pretty sure that me means replace with a higher rated axle to carry more weight than the original. If you are nice he might tell you what the min and max ratings are for your particular trailer.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 04-26-2011, 08:11 PM   #18
Globie64's Avatar
Images: 18
OK. I figured that it had a 2850 dry weight, and that we couldn't pack enough stuff to overload a 5200# axle, but I wonder what Andy would say? I've been going to Barstad and Donicht in San Leandro, I've been really happy with the quality of their work in the past.
Old 04-26-2011, 08:13 PM   #19
DanielB's Avatar
I have a 74 31' Excella. If I remember correctly Andy told me orig. was 4000, max 4400. So I went with the 4400.
- Andrew Carnegie
Old 04-26-2011, 08:52 PM   #20
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Originally Posted by Inland RV Center, In View Post
We suggest you alter the ratings of the original axles, for more pay load, and greater ground clearance. Some place can't help you with that.
Right on Andy.
Check the tag on your original axles. The original axles on our '83 were rated at 2,800 lbs. The trailer, from the factory new, empty, no water, food, nothing, weighed about 5,400 lbs.
We went to 3.500 lb, 32 degree axles. Yes, the trailer sits higher than it would with standard axles, bit I can pull into driveways, gas stations, etc. with no problem, and have an additional 2-3" clearance going down the road. Not a bad thing.
Yes, it sits higher, but isn't that why it has that nice folding step?
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 04-26-2011, 09:00 PM   #21
Globie64's Avatar
Images: 18
OKAY, now I get it: higher rating, sitting higher etc. Thats fine, we can still leap the distance from the ground through the open door. I just don't want any more sheared rivets... makes me wonder what else is going on.
Old 04-26-2011, 09:26 PM   #22
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
It's like death and taxes. On a Vintage trailer it's inevitable. You may get away from it while you fix the fridge, furnace and a dozen other things but eventually...
I found out what that second step was for after putting in new ones.
RichHog is offline   Reply With Quote
Old 04-26-2011, 09:39 PM   #23
Globie64's Avatar
Images: 18
I learned years ago, renovating a house, start with the foundation. In this case with the trailer, the axle. i've already replaced all of the plywood flooring.
Henschen replacment axles JDL Axles 14 02-04-2011 01:41 AM
