Old 04-22-2015, 07:21 PM   #15
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
My Jack
Make yerself a couple of these. Made from simple wood, screwed together with wood screws. Basic dimensions are 24L x 12W x 6H (inches, o'course). They don't break, but will degrade over time like any wood product. All they cost me was a few beers because my buddy wanted to get that odd sized chuck of laminated wood out of his shop.
They also have the added advantage of not sending money to people you don't like.
www.nesa.org
Air No. 6427
Old 04-22-2015, 07:36 PM   #16
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
The OP said 1,25" of movement, what is the correct spec?
Get right or get left, and have a blessed day !
TAC OK-5
lahrfarm is offline   Reply With Quote
Old 04-22-2015, 08:03 PM   #17
1981 31' Excella II
New Market , Alabama
1.25" from already fully loaded. How about jack it off the wheels then put one wheel on the ramp and see what the total travel is from no load to overload.
Axles become less important when you use soft riding car tires at 50 psi instead of trailer tires at 80psi. That soft tire sucks up a lot of the bumps.
Perry
Old 04-22-2015, 08:18 PM   #18
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
I own a few trailers with torsion axles and with leaf spring axles. Leaf springs have a lot more travel than torsion, when new. My question is what is the specification on a given size of torsion axel, and where would you find it. Actually, 1.25" sounds about right, but I have no spec chart to go off of.
TAC OK-5
Old 04-23-2015, 06:16 AM   #19
1981 31' Excella II
I think torsion axles are more hype that anything else. It is a disposable solution for a non-disposable problem.
Perry
Old 04-23-2015, 06:30 AM   #20
Gainesville , Florida
Hijack. Let's not let this get into an Avion vs AS debate. Ive liked all the AS I owned and think my Avion is great. But remember this is an airstream forum, vintage kin are allowed at the wim of the forum owner and the moderators. Pointing out the differences is interesting but let's not get carried away as to which Is best. There are three Avion facebook groups, I check them everyday, however they are not comparable to the Airforums. Just my opinion. I am greatful to be able to participate in the forum and the forum get togethers. Peace, jim
Old 04-23-2015, 06:34 AM   #21
1976 31' Sovereign
Springfield , South Carolina
When I ordered mine I called a torsion bar axle design engineer as my 76 Soverign had 3500 lb axles and GVW of 7100 lbs. He recommended axle loading to handle 50-66% of of the gross weight and recommended 5200 lb as the replacement which is what I ordered as that weight comes standard with 12" brakes. They can be ordered with increased down angle to raise your rig but normally they have 22 1/2° down angle.
Forgot to measure them with angle indicator yesterday when I put her back under her shed but I estimate they preloaded and rotated the axles about 15 to 17 degrees so there is some wiggle room for the big bumps.
The ride is very nice and while I wouldn't try it with anything expensive like a TV, computer etc I have left stuff on the front fold out tables and the galley counter top and after 455 mile (each way) trip, most of the stuff is still on the tables. I had a staple gun slide off running I-40 between Asheville and Knoxville which has lots of curves with recommended down speeds for 18 wheelers of 45 MPH on several of them.
It is 88 miles to the interstate system from where we live and two lane rural roads 80 miles of it and meeting 18 wheelers head on has no effect on the trailer I can feel in the pickemup.(2500HD)
I had to relieve the side plates as the square tubes are larger than the orginal but I used original holes. I had to put 1/4" plates on top so the load rests on the top of the axle plates but is secured from the side so there is no load on the mounting bolts.
This will give you an idea of how much the old axles had taken a set. Best I can figure it raised her about 1 1/4" with it on the ground.
Note the scribed line outside the original axle housing hole. This is how much I had to relieve the side plate. Note the factory bolt holes were not changed.
Check out my thread and new axles for pics.
Hummer is offline   Reply With Quote
Old 04-23-2015, 10:46 AM   #22
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I don't know whats up with the Harbor freight snobs. NOt everyone can afford a Milwaukee, or other top line tool and HF stuff works just fine. If it doesn't they take it back.
I have polished 4 Airstreams with my HF polisher. Still works well.
I don't shop at Nordstrom either
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-23-2015, 06:17 PM   #23
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
ALANSD, I'm right there with you!
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 04-24-2015, 09:53 AM   #24
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
There is a vertical plate behind the wheels. The axles mount there. Jack between the tires on that plate
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-24-2015, 11:37 AM   #25
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Originally Posted by FishByFly View Post
And where do you position the bottle jack to lift the wheels?
FishByFly
because I catch fish on a fly...
2005 30' Safari Bunkhouse
2010 F250 Lariat
Upon browsing this thread I have yet to hear an answer to the "How to test your axles". Question never answered. Everything but. Also the question posed by FishByFly, answer is behind the wheels either side marked with an "X" along the metal beam. Be careful to center the jack well otherwise you will slip onto the underbelly and have a big boo boo!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 04-27-2015, 11:27 AM   #26
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
drive the front axle up on a speed bump or some boards. See if the back one drops to the ground or hangs.
Back up and try the front one.
All this means is the rubber inside is shot and the suspension function will not work as intended making for a harsher ride.
AIR #005
retired!
