Old 12-17-2007, 06:18 PM   #1
azfiredog300's Avatar
Surprise , Arizona
How much should I expect to pay for new axles, and is it something I can do myself?
azfiredog300 is offline   Reply With Quote
Old 12-17-2007, 08:48 PM   #2
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
It depends on which axle you use, and yes you can.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is online now   Reply With Quote
Old 12-17-2007, 09:22 PM   #3
Surprise , Arizona
Pizzachop you are a wealth of information, Thank you very much.
Old 12-17-2007, 11:00 PM   #4
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Inland RV out here in Chino Ca. has your axles and he'll ship right to you.
As to can you install them? Sure thing. It's not hard at all.
Heck order now and we'll switch em out at Mt. Picachu.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 12-17-2007, 11:11 PM   #5
Correction.
We are in "Corona" Cal.
Old 12-18-2007, 12:04 AM   #6
Surprise , Arizona
Do you mean Picacho Pass?
Old 12-18-2007, 12:57 AM   #7
The FCU New Years eve party at Mt. Picachu. Which as I think about it really won't provide a clean level surface.
Honestly its not hard. Some jackstands a floor jack and some hand tools. I recomend a helper.
If you run axle swaps etc in the search engine there are several threads with pictures to show you whats involved.
Call don't email Inland RV and talk to someone. That way they can make sure all bases are covered and you'll get the right axle. Get a price and decide what you want to do.
WBCCI 6731 FCU
AIR# 13896
CA 4
Old 12-18-2007, 04:06 AM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If it gives you a point of reference the last quote I had (last summer) was 2,600.00 installed for both axles. I already have the shocks and shock bolts.
Old 12-18-2007, 09:27 AM   #9
$2600.00 is a not a very good installed price for new axles (2) with electric brakes.
Should be closer to $2000.00, plus freight.
Old 12-18-2007, 09:36 AM   #10
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I did the job myself for about $850 including the new chrome lugnuts. (2 Dexter axles)
crispyboy is offline   Reply With Quote
Old 12-18-2007, 11:02 AM   #11
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Terry did a purdy dern good write up of his axle change out here: http://www.airforums.com/forums/f221...-32395-12.html Begining around post 166.
www.nesa.org
Air No. 6427
Old 12-18-2007, 12:43 PM   #12
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
What's the skinny?
Can anyone out there simply describe the difference between installing Henschen and Dexter replacements? If I got it right the Henschens purdy much just bolt in without having to do any modification whereas the to install Dexters you have to drill 4 new holes for each axle in the mounting plate. What about the shocks? Can you use the existing mounting bolts for Henschens and Dexters?
Old 12-18-2007, 01:18 PM   #13
crispyboy's Avatar
1994 30' Excella
I used the Dexter axles.
Two bolt holes line up perfectly and the other two need to be opened up to line up properly. They are off about 1/8".
I also had to open up the mounting plate on the trailer about 3/16" (grind down one side). The dexters were the same weight rating but had a heavier axle tube.
Shock mounts - I am told that Dexters can be ordered with the mounts. I did not know this when I originally ordered. I cut off the old mounts and welded them to the new ones.
I had the tools so it was an afternoon project.
If you don't have the tools then consider purchasing Andy's axles. You may want to confirm this but somewhere I heard that you have to open up two of the mounting holes with the Henchens. Andy can confirm this rumor one way or the other.
I am just lucky enough I have the tools and know how to do this project.
Old 12-18-2007, 01:27 PM   #14
Can't help you with the Dexter information.
From 1969 on up, Henschens are direct bolt in, with no changes of any kind that need to be made.
All that is needed, is the trailer serial number.
The following information, is for those that may have further "what is the difference" between the two.
There is a very larger Airstream dealer in Texas, that this month, within 48 hours, has ordered 7 Henschen axles.
These axles are all going on 2006 and 2007 Airstream trailers, that are still in warranty, that have had their Dexter axles "fail."
The failures, as we are told, is that the rubber rods have given out and have considerably lowered the trailer to the ground.
Therefore, the owners of two 31 foot and one 34 trailer, have decided, "enough" and have refused the warranty replacements.
Instead, they are paying out of their pockets, to have that dealer install
Henschen as replacements.
This same dealer, over the course of this year, has replaced some 15 other Dexter axles, all with the same failures, and all at the more than willing customers expense.
The Airstream service department in Jackson Center, as we have been told, are more than tired of having to repair new Dexter axles before production can install them. What exactly had to be repaired information, has been withheld for Corporate reasons.
Airstream has an axle dilemma that they have recognized and have taken steps to probably change venders in short order.
Out of warranty replacements, as with anything else, is always the buyers choice.
Axles nairnchyz Axles 3 04-02-2007 02:13 PM
New Axles garthbf Axles 4 08-07-2006 07:27 PM
New axles? mtnman All Argosy Trailers 1 12-02-2005 07:23 PM
Need New Axles Navigator Axles 138 12-19-2004 10:00 AM
Do I need Axles??? blucloud Axles 3 08-16-2004 06:23 PM
