Old 08-05-2006, 11:13 AM   #15
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Originally Posted by flyfshr
Here's a pic of my leaf springs when they were taken out to replace the axle a few years back. If you count the mounting leaf, there are a total of nine. Also, clearly visible are the fairly famous skids Airstream used on a few of this era of axles.
FF
just hope your skids never need to be used!
btw i have seen them on early 70's tandem axle trailers as well. different design same function.
john
you call them ferrets, i call them weasels.
Old 08-05-2006, 11:26 AM   #16
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Ride Height
Tim,
Another thing is that by choosing between straight and drop (I think that you can get only a 4" drop) and placing the axles over or under the springs you have a lot of flexibility in ride height as well as distance from the body to axles and ground clearance on the axles. I went with a 4" drop and axles under the springs. One other thing, depending on how your tandem springs are connected compared to the new ones, this will affect your ride height also. My new connector has a 4" drop and the old one was straight.
Bill
Just my personal opinion
Old 08-05-2006, 11:55 AM   #17
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Originally Posted by wkerfoot
Tim,
The picture in post #4 is a straight axle, the drop axle has the wheel spindle above the axle. My Liner is not home now but if you want a picture I can post one later.
Bill
I'm still not quite following you. Here is a picture of mine when the bearings were being packed.
Not sure if you can see what you need to.
-Tim
theVAP - Airstream Podcast
Old 08-05-2006, 12:55 PM   #18
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Tim ~
This is the best way for me to describe an axle set-up. There are different amounts of drop and I believe you can order up to a 4" drop.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 08-05-2006, 01:56 PM   #19
1960 24' Tradewind
santa barbara , California
The springs on my 60 have 7 actual leafs there ,but I did not add the very short bottom in the count ,so 7 it is as was original .The leaves are very
thick and have the second leaf wrap up support for the spring eye as
markdoane has on his ,no added leaf was necessary for mine.I kept the
old spring packs ,just in case ,but Im sure the new ones will last another 40
years as my old ones did ,and they werent broken ,but used for sure.
Scott
scottanlily is offline   Reply With Quote
Old 08-05-2006, 01:59 PM   #20
1960 24' Tradewind
Tim , yours are original dropped axles .
Scott
Old 08-05-2006, 04:53 PM   #21
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Thanks Brad. That clears it up!
Tim ~
FF
-Tim
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 07:15 PM
Who made my axle? Pahaska Axles 44 07-25-2007 10:08 AM
one or two axle? vallan1980 Airstream Trailer Forums 5 09-17-2002 05:47 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
