Old 12-10-2010, 05:50 AM   #15
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Thanks to all for the replies. I think I will build a jig to hold the axle and prevent rotation. That should make it a bit easier, as well as more accurate.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 12-10-2010, 08:46 AM   #16
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Here is the axle 'holder' that I quickly built to contain the axle on the jack. The 'holder' is bolted to the jack. This worked for me very well.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 12-10-2010, 10:25 AM   #17
Mexray's Avatar
1978 28' Ambassador
Morada , California
I ran a description of my experience changing two axles...look here - scroll down to post# 18:
http://www.airforums.com/forums/f173...tml#post925341
Ray
Ray & Pat; Morada, CA
Old 12-10-2010, 10:57 AM   #18
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
Andy, What is the life expectance of axles on a 34' airstream trailer.
I'm surprised they would need replacing already.
I would appreciate your professional advice on this!!!
william Haym is offline   Reply With Quote
Old 12-10-2010, 11:39 AM   #19
1989 32' Excella
Limestone , Alabama
Took me about 8 hours to swap out 2 axles, with the second axle taking about half the time of the first due to the learning curve.
I had two small, cheap hydraulic jacks (one at each end of the axle) that I used to lower the old and raise the new axles in place. To keep the axles from rotating - I used two 3 inch capacity spiral hose clamps (radiator hose size) connected together and looped over the axle and under the saddle of the jack. Tightening the clamps "tied" the axles to the jacks preventing the rotation of the axles during the remove/install. I lowered each jack a bit until the axle was down on a furniture trolley in the center, then c-clamped the axle to the trolley to prevent it from rotating, removed the spiral clamps from both ends and used the trolley to move axles. With many thanks to all on the forum for all the other info needed to make the swap easier than expected.
Best wishes on a successful axle swap!!!
Steve
war eagle is offline   Reply With Quote
Old 12-10-2010, 12:15 PM   #20
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Here is how I installed the new axles on our Excella.
I put a piece of tape around the axle to mark the center. Placed the axle on the floor jack lengthwise and rolled it under the trailer. I then jacked the axle up until it was starting into the slot. At that point my wife got on one end and I on the other and gave a little lift to the trailing arms to get the axle in the right orientation and the axle started right up into the slot.
Jacked it the rest of the way and inserted the bolts. It took me about as long to get it into place as it did to type the story here.
ID:	116816   Click image for larger version
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 12-10-2010, 01:08 PM   #21
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Did my Caravel single axle in 3 hours - including the drilling of new holes for the bolts. The next one would not take me near that long - maybe 2. There is a learning curve, you are lucky, withg multiple axles you only need to drive the tralier up on the axles not being changed out to lift the trailer up - mine was on jack stands.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Lucille Ball, The Long, Long Trailer Lothlorian Off Topic Forum 19 12-01-2009 06:19 AM
TCT 40' Long Air Stream Dual Axle For Sale wheel interested Other Clubs 16 02-29-2008 01:13 PM
Our long, long trailer (AKA 19' CCD) crazylev 1997 - 2004 Bambi 60 05-11-2006 12:53 AM
There's a long, long trailer in front of my house - 2004 Classic Porky Pig 2001 - 2005 Classic 35 01-28-2004 05:28 PM
