Old 06-30-2014, 11:49 AM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If the elastomer takes a set. The axles will ride hard.
I would not replace the axles until you are ready to travel.
Even if the coach is raised with the weight off. The elastomer will take a set. Because it loses the elastic ( flexing) ability. Similar to the way a tire ages and gets hard. Only it takes longer.
Traveling with the coach is the best way to keep the axles in shape.
Old 06-30-2014, 11:53 AM   #16
Absolutely correct.
Old 06-30-2014, 12:16 PM   #17
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I just finished replacing the axles on a 1994 trailer for a couple of reasons.
- the trailing arms were pointed upward (made no difference on the load therein)
- interior rivets popping
- wheels did not drop very far when jacking the trailer up
- The trailer is 31' long and was wanting to drag on steep approaches.
It is likely I could have gotten a bit more life from them but I don't like to skip on maintenance. I saw the lack of a good suspension as potentially causing other problems down the road. I plan on keeping this trailer for awhile. The trailer has a nice "springy" feeling when you walk toward the back.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
At Last - At Last pt1949 General Interior Topics 9 02-03-2014 10:40 PM
How long should a battery last? wacnstac Batteries, Univolts, Converters & Inverters 28 09-08-2006 08:39 AM
