Old 04-26-2012, 05:45 PM   #1
1989 29' Excella
Cumming , Georgia
How do you know when a coach needs its axles replaced
HI,
I'm cautisously considering buying a used Airstream. I've heard that if the top of the wheel well is covering the wheels/tires it's an indicator that the axels need replacing.
In many, MANY of the pictures all over the internet it seems that the wheel well is very near the top of the tire or edige of the wheel.
I don't even want to waste the time, (or travel expense), viewin a coach that is at risk of needing it's axels replacing.
Is it a hard rule that if the wheel well is over the wheel/tire the axels need replacing?
Help!!!!
davcarv is offline   Reply With Quote
Old 04-26-2012, 06:44 PM   #2
Originally Posted by davcarv View Post
HI,
Help!!!!
That's about a 99 percent guarantee.
Or, the rubber rods have solidified, so that there is zero life in that situation.
Old 04-26-2012, 07:10 PM   #3
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
But replacing the axles is not death sentence.
If one is capable of turning a few bolts and crimping a wiring connection, an older trailer in good shape otherwise is still a viable option.
As long as one allows for the fix in negotiating the purchase price I would not let an axle upgrade put me off a purchase.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 04-26-2012, 07:33 PM   #4
Regards,
JD
Changing out axles on 1969 and newer Airstream's, is a piece of cake.
Takes a little more effort on 1968 and older Airstream's though.
Hundred's of owners have changed out their own axles.
Old 04-26-2012, 08:32 PM   #5
1989 29' Excella
Cumming , Georgia
Thanks for the feedback.
So the concern I'd have is let's say I find a viable prospect. Buy it...how do I know it's even road worthy,... From an axel perspective?
Old 04-26-2012, 09:36 PM   #6
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
If its not dragging the bottom,, it can be towed... My axles did not look real bad when we got our Overlander the last part of Feb of this year.. but once loaded up with gear,, and full of water it sank more than what I am happy with so got a set of new axles just a week ago from Inland Rv.. Great price and will be a bolt in job as it has the right brackets already welded on the axles..
Not had the time to slip them in yet but I have soaked the bolts with what we call cat piss and other than the gas line is under the axles I will have to take them down.. Looks like at best a 2 hour job once my mental gears are focused for that project. .
I will say that the limited miles we have gone while loaded I have been very careful how fast and hard I would charge down the road.. No need to do any long term damage to our old gal,, who we named " Time Machine"
Like they said,, find a trailer you might like and reason with the owner that your looking at $XXXX$$$ to get new axles and $XXXXX$$$ for the labor to install. I wish now I would have pulled that card when I was dealing on ours at the time.. I felt they were weak but he had come down $4000 from where we started and did not want to push him to hard and come home empty handed..
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 04-27-2012, 09:00 AM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The gas line runs under the axle! Wow! Haven't seen that setup. Is it black iron pipe?
What is the difference between the '68 and older and the '69 and newer models?
Old 04-27-2012, 09:17 AM   #8
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Odd that you 'say' that, Andy. I replaced my tandem axles on my '66 a few years ago with axles purchased from you and excellent guidence from Greg, on your 'staff'. The process was easy if not slow for me because of recent hip (2) replacement....hope my Dr. doesn't read this...If you are potential owners of a vintage AS it's a 'fact of life' that axle replacement is inevitable but not a deal breaker.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 04-27-2012, 09:18 AM   #9
The axle mounting plate dimensions was different in the 68 and older Airstreams.
That plate was changed for the 1969 models and is still used today.
Basically, the bolt holes will not line up on the 68 and older trailers, when installing new axles, which requires drilling some new holes.
Also, the distance between the mounting brackets is different. Likewise for the wide body coaches.
Old 04-27-2012, 09:19 AM   #10
FreshAir's Avatar
1966 24' Tradewind
Its copper.....and easily removed and replaced.
Neil
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 04-27-2012, 09:34 AM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Is the axle too close to the belly pan, thus preventing the attachment of the gas line flat against the belly pan?Seems to me it would be prone to road damage hanging below the axle.
Old 04-27-2012, 10:33 AM   #12
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Copper gas lines
Yep,, copper lines,, and loop under each axle.. Dont think they are factory,,, but well mounted other than the axle loops.. Cant see why they did it that way as the gap between the top of the axles and belly pan has to be 2" ..
So will end up cutting and going back with compression fittings to seal right.
Raining cats and dogs today,, good day to swap axles but my trailer is parked off the main drive and cant get it out till the mud settles.
Sodbust
Old 04-27-2012, 11:06 AM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Better get to it, the rally is a week from today. LOL
Rained here a little last night.
Old 04-27-2012, 11:08 AM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I've heard that you should use flare fittings on gas lines. Not compression. Don't know how true that is.
