Old 04-09-2014, 10:48 AM   #1
1990 29' Excella
Long Island , New York
How Do I Get This Bolt
This is the rear axle bolt, the end of the thread is about a quarter of an inch away from the tank shroud. Cut off wheel wont reach it torsion arm blocks front of bolt, open end on both sides aint gonna do it. Drop tank covers I'm thinking?? I hope the tanks are supported by something other than the cover. Any Ideas??
Jeepjunk4 is offline   Reply With Quote
Old 04-09-2014, 11:05 AM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Box end wrench (preferably six point so it's less likely to strip the flats off the nut) with longest cheater bar that will fit the space. Might have to grind the wrench down a little so it will fit between the end of the bolt and the tank cover.
If it won't turn, perhaps a Sawzall.
Good luck. Same project in our near future.
Old 04-09-2014, 11:08 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
choices choices
1. you should be able to get a box end wrench on the nut and another one on the bolt head. May have to pry the tank shroud away a little bit to slide it over the bolt.
Use a real box end not one of those ratcheting ones; ratcheing ones are larger and might not fit. A six-point box end will shear the bolt before it slips
2. failing that you can try a fitting wrench which will give you quite a bit more torque than an open end wrench but not as much as a box end
3. should be able to get a vise grip on the bolt head too
4. cutting torch (using a wet rag to protect things that need it)
5. sawzall
With either the torch or the sawzall you have the choice of cutting through the nut or just shortening the bolt to the point where you can get a wrench on it.
Old 04-09-2014, 11:09 AM   #4
1981 31' Excella II
New Market , Alabama
It is a little hard to tell what is going on there. You are trying to remove that bolt that is blocked by the torsion arm? How is removing the tank cover going to help? A cutting torch will get that baby out. Are you replacing the axles?
The holding tanks are supported by the pans only. The tank pans are thick steel. You will most likely find that the bolts holding the pans will break before they come loose. Airstream must have done a lot of research into finding just the right alloy of bolt so that once it is put in that is rusts and won't ever come out. The same goes for the bolts that hold the bal jacks on.
Perry
Old 04-09-2014, 11:13 AM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I'm not able to see all of the area you're working in, but a suggestion. Heat. Don't jump yet. Shield what cannot tolerate the heat with a steel heat shield like a plate of steel and use a butane micro torch. A rather small hot controlled flame MIGHT work. Remember I'm not seeing the whole thing clearly. Be careful busted knuckles hurt big-time. Also spraying with PB BLASTER or other repeating frequently for days might be enough.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 04-09-2014, 11:40 AM   #6
1990 29' Excella
What you don't see in that pic is the tank cover, which is just off the end of the bolt, I'm talking quarter inch. Don't have a torch, front axle used cut off wheel on back sie, cut thru nut and bolt flush to axle flange so pushin gbolt out wasn't a problem. So the back pan holds the tanks up, jeez, I don't want to break anything in there. I took off the front fresh water tank cause it had a leak, but that also helped access the bolts. Sawzall didn't seem to work on front bolts so used cutoff wheel, and the ones I could wrench, big breaker bar with my feet on it barely got em going, so open ends and vise grips won't cut it, ya need some big torque here.
Old 04-09-2014, 11:42 AM   #7
1990 29' Excella
Oh, and pb blaster for 2 weeks didn't seem to do anything.
Old 04-09-2014, 12:08 PM   #8
1981 31' Excella II
You need a nut splitter. Yes that is a real thing. It is a loop shaped thing with a blade driven by a bolt. You tighten the bolt and it drives a blade into the nut and it eventually breaks it.
nut splitter tool from Northern Tool + Equipment
Perry
Old 04-09-2014, 12:14 PM   #9
teebs32's Avatar
1977 31' Sovereign
mansfield , Ohio
I second the nut splitter. They also have them at harbor freight ... Not the best quality but will do the job for sure.
teebs32 is offline   Reply With Quote
Old 04-09-2014, 12:21 PM   #10
1990 29' Excella
I don't think a nut splitter will fit but even if it did the bolt will not come out past the torsion arm. It ideally needs to be torched, Im going to the tool store to find the toughest sawzall blade I can.
Old 04-09-2014, 01:53 PM   #11
Kevin245's Avatar
A sawzall with a bi-metal blade will take care of this in short order.
Eleanor Roosevelt
Old 04-09-2014, 04:43 PM   #12
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
If you jack up the trailer will the torsion arm still be in the way?
putback is offline   Reply With Quote
Old 04-09-2014, 05:44 PM   #13
1990 29' Excella
Yes the torsion arm is still in the way, and Kevin u were right the sawzall did it, but hardly in short order. I went to my tool guy and got a 5 pack of lenox 14 tpi blades and used em all, but got em. I would say a half hour per bolt, but wait, the saga continues.
Got all bolts out disconnected shocks, and the curb side axle didn't seem to want to drop. got a pry bar under the axle flange, but it still wouldn't come down. The street side was free, now on closer inspection, look at the pic. Remember ur looking up from the ground. The black and rusty thing is the axle tube, the oxidized thing is the black and grey tank shroud. Now look at the rusty axle flange that runs across the top. It appears to me,that when the tanks were installed, the shroud was notched out to clear the axle flange, which is also preventing the axle from dropping!!
Now, options, drop the tanks,which I really don't want to do, or take cut off wheel and try to notch out tank shroud without cutting into tank. Im thinking there must be at least a half inch of insulation around the tanks??? idk whaddya think?? I do know beer makes everything better!!!
Old 04-09-2014, 07:28 PM   #14
teebs32's Avatar
1977 31' Sovereign
mansfield , Ohio
This is the best blade I've used yet to cut metal with
Great deal but No Title, Should I get it? How to get title in MI or NY? Gypset Title, VIN & Registration 13 03-28-2017 05:15 PM
Bolt pattern to get a spare mgordon Wheels, Hubs & Bearings 11 05-05-2015 12:17 AM
T Bolt - Where can I get some? MrJ Mechanics Corner - Engines, Transmission & More... 3 11-17-2011 06:38 PM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
