Old 04-10-2014, 09:10 PM   #15
Kevin245's Avatar
Originally Posted by Jeepjunk4 View Post
Yes the torsion arm is still in the way, and Kevin u were right the sawzall did it, but hardly in short order. I went to my tool guy and got a 5 pack of lenox 14 tpi blades and used em all, but got em. I would say a half hour per bolt, but wait, the saga continues.
Got all bolts out disconnected shocks, and the curb side axle didn't seem to want to drop. got a pry bar under the axle flange, but it still wouldn't come down. The street side was free, now on closer inspection, look at the pic. Remember ur looking up from the ground. The black and rusty thing is the axle tube, the oxidized thing is the black and grey tank shroud. Now look at the rusty axle flange that runs across the top. It appears to me,that when the tanks were installed, the shroud was notched out to clear the axle flange, which is also preventing the axle from dropping!!
Now, options, drop the tanks,which I really don't want to do, or take cut off wheel and try to notch out tank shroud without cutting into tank. Im thinking there must be at least a half inch of insulation around the tanks??? idk whaddya think?? I do know beer makes everything better!!!
JJ4,
Glad to hear the sawzall worked for you, sorry to hear that it did not move fast. Blade quality and saw speed is key to good cut success. We've used ours to cut 2" x 16" reduced section tensile samples from large W-Shapes with great ease and I am talking about 3/4" thick steel. We were cutting a sample out in 15 minutes while working with the tool overhead. Our sawzall was variable speed though and blade control was easy.
And yes beer does make everything better.
Eleanor Roosevelt
Old 04-10-2014, 09:27 PM   #16
Central , Mississippi
If you only have a hammer, everything looks like a nail...
i don't even own a sawzall, but I have done a couple of axle swaps and a cutting torch makes quick work of the bolt.
i guess it comes down to your available instrument of destruction!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 04-11-2014, 06:55 AM   #17
1990 29' Excella
Long Island , New York
Ya know what Kevin, u said saw speed, now that I think about it the saw cut real good initially, then when the blade heated up, it seemed to go nowhere, now I'm thinking I should have slowed it down abit, good point. And yes smoke wrench would have been the tool of choice for this job, but not for notching the tank, lol.
Jeepjunk4 is offline   Reply With Quote
Old 04-30-2014, 10:59 AM   #18
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Let us know how you finally get the rear axle to drop down. I just looked at my trailer the other day and was wondering how I'm going to do this job. It is made the same way. It seems like the only options are to drop the tank pan or notch it out and patch with some heating duct galvanized metal.
I wonder if you could just drop the front of the pan down 1" to slide the axle out?
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 05-01-2014, 09:23 AM   #19
1990 29' Excella
OK, Steve this is gonna get ugly, I just want u to know what ur in for. When I did my axles I wanted to dropthe fresh tank, because it had been leaking and the pan had been hit before, what rocket scientist thought it would be a good idea to hang the fresh tank lower than the axle, ok, I'll stay focused!! So I took the 14 bolts out pried off the gak holding it, and yes the whole tank comes down, disconnected everything, made the job waaaay easier.
I'm a guy that's turned wrenches my whole life, my garage is pretty well equipped, air, welder, gave up my torches years ago when acetylene became a pita to get around here, so the cut off wheel has become my best friend. The front axle came out pretty easy, I sprayed the bolts for weeks ahead off time, still those babies were tight. I'm talking, breaker bar, cheater pipe, 2 feet finally cracked em. Now the front bolt on the axles are doable, remember I got the tank out too, but the rear bolts wont come out past the dead torsion arm so ya gotta cut it, 4 1/2 inch cut off wheel just fit, from the back side of the frame. Having fun yet?? Front axle dropped out, on a floor jackjust like I planned.
Now since I have all this room, I' gonna block the trailer up from the back, and pullthe rear axle. The front bolts were a bitch but got em out. Now the back bolt on the curb side u can see it but ya cant get a wrech on the back side of it because the tank pan is snug to the framerail, the end of the bolt is about 1/4 inch away from the pan. So realizing theses bolts need to be cut anyway, theres no way I can get anything on the backside of this framerail, no room. I went to the tool store and got a 5 pack of bimetal sawzall blades, and probably 1 hour and 5 blades later, both rear bolts were cut from the front, cut the heads off.
Ok its not dropping!!! WTF!!!! See my other thread. All in all it's done. Was it a bitch??? Oh yeah!!! Right now I just have more time than money, and I really like to know how these things work. I would highly recommend torching the bolts off, that would have made this job a breeze, and I did snap 2 of the shock mounts off the frame, but welded new ones on, no big deal. I did have somebody pm me that they took delivery of the axles and drove straight to a trailer repair shop, and they installed them for $250!!! Now that's a smart man!!! But I'm in NY, and he lives in Texas, nobody's doing anything for 250 around here!!!
If you want anymore help or advice, just pm me. Good Luck.
Chris
Old 05-01-2014, 09:45 AM   #20
1990 29' Excella
Oh and one more thing, there is no sliding the axle forward, they go straight up and drop straight out, and as far as removing the grey and black tank shroud, I was told the tanks will come down with it after ur done snapping all the bolts off, that was a last resort. I also filled the void iin the corner of the tanks with expanding foam, I will seal it better at the end of the season, I'm in camping mode now!!!
Old 05-08-2014, 11:49 AM   #21
crispyboy's Avatar
1994 30' Excella
Glad you got the job done. It sounds like you had to notch the gray/black tank shroud. I have taken this larger tank shroud down on the 89 model which is something I don't want to do again. Had no trouble with the bolts breaking but I used an impact wrench which seems to do a better job on rusty bolts that brute strength. The brute in me always snaps the bolts much quicker.
Got my axles ordered but I won't be doing this job until July.
WBCCI # 3072
Great deal but No Title, Should I get it? How to get title in MI or NY? Gypset Title, VIN & Registration 13 03-28-2017 05:15 PM
Bolt pattern to get a spare mgordon Wheels, Hubs & Bearings 11 05-05-2015 12:17 AM
T Bolt - Where can I get some? MrJ Mechanics Corner - Engines, Transmission & More... 3 11-17-2011 06:38 PM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
