Old 07-21-2009, 11:20 AM   #29
Originally Posted by ROBERT CROSS View Post
On the ground all axles are almost dead even with the mount channel and all dropped to the same angle when jacked, again a good sign..I think.
One question, if I have about 3"s rebound, do I also have 3 of compression? If it's not too hectic around here when we leave, I'll try for some photo's when we are loaded and see how much angle I've lost.
So all, what do 'ya think?
Bob.
The 3 inches of travel is good.
The problem is bottoming out.
When the torsion arms are almost parallel to the ground, with no pay load, then when the pay load is added, it's wise to check the position of the arms again.
There is a built in "stop", which will cause bottoming out, when hitting some bumps. When the arms are parallel when loaded then the trailer is about at it's limit.
If the arms are going up hill when the trailer is loaded, then bottoming out will happen.
Bottoming out, lack of proper running gear balance, excessive rated hitch bars and super heavy duty tow vehicles, all contribute to damaging the trailer, in one way or another.
Was your ever Airstream parked for an extended period of time? If so, then that's the likely cause of the problem.
The rubber rods in the axle housings, must be exercised, to stay alive, at least every year or so, to be safe. Towing it a few miles at least once a year, will prolong the life of torsion axle rubber rods.
Old 07-21-2009, 02:32 PM   #30
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Andy,
Thanks once again for your input, you are a valuable asset here.
I have been rather anal about how I store the trailer during the off season, as you can see everything comes off including the Arrow.
We are going to be fully loaded this Saturday and I will check them again. Will also stop at the scales.
Our Suburban does have Autoride but without the auto leveling. Tongue wt is 960 on the Sherline scale, about 100 of that is the Arrow. I use 1000# bars and transfer between 140-160 to the trailer with the jacks set 1/2 way between the 2nd and 3rd marks. I get about a 5" rebound when bouncing my 170#s on the tongue. The Burb is a very smooth riding TV and if I'm not bottoming out should not bounce the coach around.
Name:	2007 WINTERIZE 007.jpg
ID:	84267   Click image for larger version
Name:	06 BURB SHAKEDOWN TRIP 018.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 07-21-2009, 03:04 PM   #31
Paul Mayeux's Avatar
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
We went through this song and dance as well. Our '05 International 25' started to noticeably sag on the curb side. I noticed one day while rotating the tires that with the rig on jack stands, the torsion arms on the curb side did not return to a normal down position with the weight removed. The street side did. A check of the plate on the side of the trailer and the tag on the axles confirmed that Airstream installed 3,000 lb axles. A trip to the scales, without the trailer being fully packed for travel but with full propane and fresh water and a Hensley hitch showed the rig to weigh 6,840 lb.
Subsequently I ordered axles from Inland, they recommended 3,800 lb axles.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 07-21-2009, 04:44 PM   #32
[QUOTE=Minnie's Mate;
You probably had axles actually rated higher than what it is labeled but they are probably labeled lower per Airstream's requirements.[/QUOTE]
Your "probables" can be very misleading to many owners.
What the label says, is what they are.
That information comes from sources deemed to be the experts in specing out the manufacturing details.
Old 07-21-2009, 06:37 PM   #33
VIKING's Avatar
Boulder Creek , California
I'm glad you chimed in on this Andy. I can't imagine what kind of problems would arise if the axles are labled at a higher or lower weight then they are manufactured. If my shop told me this I would be very distressed. How could you know what your capacities are without accurate axle ratings?
Rich
VIKING is offline   Reply With Quote
Old 07-28-2009, 10:29 AM   #34
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
I don't profess to be an expert and I think everyone on the forums realize that. I am going by what one "expert" (utility/car/horse trailer re-seller) told me and I give the details of that discussion. The shop I use is a full service shop that has been in business for many years and many of the trailers he sells come with Dexter axles.
I realize most consider your advise as gospel, they do not have the same opinion of me. I can only pass along my experience as everyone else does when they post any information they want to share.
Family of Disney Fanatics
WBCCI# 4821
OK To Use E Rated Michelins LTX/MS fr8tshaker Tires 11 01-29-2011 11:49 AM
Who makes E rated Rims Chitown AirStreamers Wheels, Hubs & Bearings 2 08-04-2008 10:18 AM
Honda rated #1 by JD Powers Road Ruler Tow Vehicles 23 08-07-2007 05:40 AM
Rated tire speed - Can I get faster than 62? Goin camping Tires 1 09-25-2006 05:29 AM
extension cord rated for 20 amps? Martha Electrical - Systems, Generators, Batteries & Solar 15 02-28-2003 03:00 PM
