Old 07-07-2015, 08:54 PM   #1
Mission , Texas
How can you tell/know?
What axle(s) you currently have?
If said axle(s) are original or replacement?
What hubs you have? (so seals can be ordered before opening them up)
What brakes you have? (so new shoes can be ordered)
Sorry if this is repetition, I searched and got tired. I like one stop shopping, so hopefully this will work.
Thanks beforehand!
nrgtrakr is offline   Reply With Quote
Old 07-07-2015, 09:02 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
1. Should be a label on the axle.
2. ?
3. If worse comes to worse you can pull one and go to any auto parts store and buy them. I have found NAPA to be very good for that.
4. See #3
MICHAEL
Old 07-07-2015, 09:40 PM   #3
Mission , Texas
Very good, thanks!
In 1971 my first vehicle was a 1941 Ford pickup. The adventures of resurrecting an abandoned and neglected 40 year old AS that was slightly abused by most likely nice people with tools is bringing back memories.
Some are mechanics, others are nice guys with tools.
Old 07-14-2015, 03:51 PM   #4
Mission , Texas
Another potentially goofy axle question ...
Supposedly when a torsion axle is loaded (bearing weight, as in under a trailer holding the trailer up) the rubber inside eventually takes a "set", or ~sags~ from the weight. Which in turn gives us reason to change them.
But what happens if the axle is not loaded? The tires are hanging down dangling thier toes in the air.
What effect (if any) would unloading an axle that has taken a set have on the set? Visualize axle CPR, or occupational therapy.
Would giving the axle a vacation prolong its life?
Or would the torsion rubber inside freak out and break causing the wheels to fall to the ground or worse while towing?
Old 07-14-2015, 04:47 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
If the axle has taken a 'set' hanging it after the fact won't help.
I always unload the axles during Winter storage, it does help extend their life, up to a point.
With our I Classic I feel it's important as we have a 7300lb GVW rated trailer with two OEM 3500lb axles. Every little bit helps.
Old 07-14-2015, 05:55 PM   #6
Torsion axle rubber rods, last about 25 years, but only if they are some what frequently used, like 2 to 3 times a year or more. If they are not exercise, by movement, then the rubber rods will most likely solidify.
However, if the entire weight is removed from the axles, when the trailer will be in storage for a reasonable period of time, then the rubber rods will last much longer. How much longer is not known, but information as to a longer life, if treated with zero load, says perhaps another 5 to 10 years. But that is engineering points of view, and estimates, with very little feedback. However, at least in theory, there is some truth to that opinion.
Once the rubber rods have taken a set, nothing short of replacement will correct that issue. When removed old axles are examined, the torsion arm never moves, even after a couple of years.
Torsion axles provide a soft ride for the trailer, which is a must, but not forever. Torsion axles are a great suspension system, but they do have a limited life. Twenty five years, and they are done.
Old 07-14-2015, 09:20 PM   #7
Mission , Texas
Thanks Bob and Andy! Good to know it might be possible to squeeze a little more out of them, especially since they aren't recyclable.
Andy, is there a way to know an axles age, like a date stamp or something?
I read the axle write up on the Inland website, and on second evaluation mine are borderline (almost 0 from positive, so slightly positive). And this rig basically sat for a couple of years before I bought it last month. We want to winter in Texas, and hopefully I'll have it usuable before then (it's a mess). I'd prefer to change axles in Texas as where we are currently is middle of no where.
Also how does one become a "real" RV mechanic, as in certifiable? Endorsements for solar, gas, etc. In previous work incarnations I've been a radar/missile system tech, builder of houses, maker of cabinets, and stationary engineer.
Old 07-15-2015, 09:49 PM   #8
Mission , Texas
Two more ridiculous questions ...
Convert to conventional springs?
Use the dying torsion suspension as host to an air suspension?
Comments ...
I know one of you will know how to... AIR-Quarius Cleaning, Stripping & Polishing 1 05-31-2014 10:45 PM
How can you tell the towing capacity? Dreamnair Tow Vehicles 4 01-04-2009 07:40 AM
Can you tell me what Heater I have in my 1999 Safari 25'? Aluminumb Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-02-2008 12:12 PM
How can you tell if your freshwater tank is truly clean? JimGolden Fresh Water Systems 24 10-30-2007 08:44 AM
Can you tell we're hooked? FordTruck On The Road... 10 05-16-2007 06:12 AM
