Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 06-14-2009, 06:21 PM   #1
Profile:  1974 Argosy 24
Winston Salem , North Carolina
Hot Hub on new Axle
Greetings everyone
we just had our first 20 mile outing on a new set of Henschen Axles
The good news is , they are still where they belong.
One hub got hotter than the 3 others, almost to hot to touch
do i need to worry?????
anyone with advice out there, i would love some feedback
Michael
michael13 is offline   Reply With Quote
Old 06-14-2009, 06:39 PM   #2
Profile:  2008 25' Safari FB SE
Crawford , Colorado
Sounds like failing wheel bearing, possibly not enough or too much grease, castellated nut too tight, grease seal failure or locked up brake. Only way to find out is to take off the wheel and then the hub (brake drum) and look.
Gene
CrawfordGene is offline   Reply With Quote
Old 06-14-2009, 06:43 PM   #3
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 65
Airstream Registry
It could also be a break adjusted too tight. Once you get the wheel in the air you can check for break drag.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 06-14-2009, 06:46 PM   #4
Profile:  Corona , California
Originally Posted by michael13 View Post
Greetings everyone
Michael
Michael.
Please don't guess or assume. Pull the wheel off and get to the exact problem. Correcting it, should be easy.
Also check the tire pressure, and make sure it's what you want it to be.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-14-2009, 06:49 PM   #5
could you explain break drag????
Old 06-14-2009, 06:51 PM   #6
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
the brake drum should spin freely with the wheel hot. the brakes will drag more as the drum heats up so don't adjust them too tight when they are cold.
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Old 06-14-2009, 06:53 PM   #7
Phoenix , Arizona
Images: 65
Airstream Registry
If the breaks are adjusted too tight, the shoes will rub (drag) on the surface of the drum all the time. This will cause the drum to heat up.
Richard
Old 06-14-2009, 07:01 PM   #8
Originally Posted by Inland RV Center, In View Post
Michael.
i just went out and the drum is much warmer than the almost cool rest
without taking the wheel off and ................ Then What???????
my instinct is that the break shoes on this side are to tight
according to the manual it should be a quick fix
any advice?????
Old 06-14-2009, 07:10 PM   #9
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
any advice?????
Yes. Jack it up, remove the wheel, and check the brakes and bearings.
(No Longer at Inland RV)
Old 06-14-2009, 07:14 PM   #10
I can do a lot of things but i have never taken a break drum apart
How
Old 06-14-2009, 07:24 PM   #11
Well-Preserved
How
Who put the brake drums on your new axles? Taking the drum off is not hard, it does require a little mechanical ability. Raise the trailer, either using a jack, or the driving-it-up-on-a-2x6 method, and remove the tire and wheel assembly. Loosen the lug nuts first. After you remove the wheel and tire, pop the dust cap off the hub. Remove the cotter pin that goes through the castellated nut, and unscrew the nut. Remove the washer that's under the nut, and remove the outer wheel bearing. It should just slide out of the hub. Put all these parts somewhere clean and dry. After you do that, simply slide the hub and drum assembly off the spindle.
After you get the hub off, you can look to see if anything brake related has fallen off, and is causing the problem. Examining the parts is not tough, make sure the bearings have grease on them, and nothing is rolling around inside the drum when you remove it.
Now, if there isn't any grease in the bearings, you'll need to repack them. If, after removing the outer bearing, you can't slide the drum off the spindle, the brakes are probably too tight, for one reason or another. There is an adjuster wheel on the backing plate, and it adjusts by being rotated up or down.
Old 06-14-2009, 07:30 PM   #12
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
How
Go buy a case of beer (brand not important) and then wait until I pass thru on the way home sometime in August or September....or follow the directions that Overlander63 gave you.
Aaron
WBCCI #2449 AIR #2495
wahoonc is online now   Reply With Quote
Old 06-14-2009, 07:32 PM   #13
well the axles came fully assembled from the factory
is there a way to test if the break shoes are to tight before i disassemble the drum ?
Old 06-14-2009, 07:35 PM   #14
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
Get the wheel off the ground and try to rotate it, if you feel drag or it is hard to rotate by hand it is too tight. When I adjust brakes I run them up until the wheel drags then back off the adjuster a bit until it no longer scrapes. Hard to explain but easy to do...
Aaron
tag axle drum and hub assembly str8strm Mechanics Corner - Engines, Transmission & More... 13 12-20-2007 02:26 PM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Hub Help frozen chosen Axles 6 05-01-2005 04:55 PM
Hot hub Pahaska Axles 5 04-22-2005 03:29 PM
Hub caps davespann Parts Archive 7 07-30-2003 08:29 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
