Old 06-16-2009, 07:58 PM   #43
blacksheep's Avatar
1965 26' Overlander
1962 24' Tradewind
Vincennes , Indiana
Gene,
You are correct, farm implements don't see much speed. But boat trailers with grease zerks in the dust caps do.
Godspeed,
Trent
TV1: Black Sheep, 2001 Dodge 3500, 800,xxx miles, a few non-stock parts here and there...
TV2: Brownie, 1989 Dodge W250, only 256,000 miles!
TV3: 2004.5 Dodge 3500, 415,000 miles, 6 spd
TV4: 2005 Dodge 3500, 478,000 miles, 4spd auto
"Too much of what I once knew I now know not" Me
blacksheep is offline   Reply With Quote
Old 06-16-2009, 08:12 PM   #44
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Originally Posted by eubank View Post
You know, I was looking through this booklet thing that Andy sent along with our new axles and hubs. It's got a diagram of a different hub assembly that includes a zerk. Apparently, you just connect on with the grease gun and pump the thing full. (That'd be a lot easier than the "method" I use.)
Lynn
The new axle I put on our Caravel six years ago has a zerk fitting in the center of the spindle that lets grease exit the spindle between the inner and outer bearings. The idea is to pump grease until it comes out the outer bearing. The seal is supposed to keep the grease from exiting the back of the hub and getting on the brake lining. Doesn't work so well. The grease that has been running in the bearings seems to break down, and when the new grease is pumped through the bearings, it forces the old grease out. Some of the old grease went past the seals.
I now use the "old way" of packing the bearings on the Caravel.
Old 06-17-2009, 06:35 AM   #45
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Too Much Grease No Way
Lynn
My new axle on my GT has the grease zerk fittings,they will be pumped full.they have a relief on the outside ,so as not to blow the seals. Dave
PS I think seals should not be left in there for 6 years.
easyride is offline   Reply With Quote
Old 06-17-2009, 07:38 AM   #46
Baltimore , Maryland
Firstly I am glad some of you know the difference between Breaks and brakes...
If you still have a hot hub, it could be the chase is not true. sometimes the tooling slips and it occurs. Fortunately for you, you bought the super deluxe brand and the seller will make sure it is right in the end.
Old 06-17-2009, 07:51 AM   #47
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The seals were not left in for six years. They were replaced when I found the problem, and get replaced every time I pack the bearings.
Old 06-17-2009, 09:03 AM   #48
1974 Argosy 24
Winston Salem , North Carolina
I just got the word from my RV mechanic that everything is in order they could not find anything wrong.
so it looks like that i found all of the problems and installed everything the right way
hopefully we will be on the road this afternoon
thanks to everyone
i will keep you posted after a longer trip
michael13 is offline   Reply With Quote
Old 06-21-2009, 01:09 PM   #49
1974 Argosy 24
Smile all is well
after 350 miles on the road all hubs are cool
no problems the trailer is pulling well on its new running gear
Thanks again to everyone who has contributed to this mystery
onward to new adventures
Michael
Old 06-21-2009, 03:00 PM   #50
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Glad to hear it. Do you have one of those laser temperature things? You can check tires and hub heat when you stop to catch problems before they get dangerous. I think they run around $50 and I got mine through Amazon.
Gene
Old 06-21-2009, 04:27 PM   #51
Michael
Did you install the new parts we sent you?
Old 06-21-2009, 05:14 PM   #52
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
This thread was giving me all sorts of stomachaches, so this morning when I finished installing our new axles and brakes, I took a short ride, felt the hubs, took a longer ride, and felt the hubs. Nice and cool!
Lynn
WBCCI 21043
Old 06-21-2009, 05:23 PM   #53
1974 Argosy 24
Thumbs up
Yep, since i know now that it was not my craftsmanship i ripped it apart again and installed the new parts, becoming a pro in this
Thanks again for the great customer service.......
I figured that this specific hub was a freak accident in the assembly department
so, here is my new adventure
AIR CONDITIONER
check it out
Old 06-21-2009, 05:30 PM   #54
Lynn
COOL.
Failures can happen to most anything.
Even one in a million, is a failure rate.
Diamonds break, too.
Glad you can now sleep good.
Old 06-21-2009, 07:47 PM   #55
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Oh, I'm going to sleep VERY soundly! My body just can't take too much physical exertion any more (though that may have to do with my being too much a fan of Sonic hamburgers).
BTW, I had to raise the hitch once all was said and done. It's now 2.5 inches higher; we'll see how that fits with the rig once I'm feeling more fit.
Lynn
WBCCI 21043
Old 06-21-2009, 08:14 PM   #56
Lynn
Lynn.
That's about the average new ball height after new axles are installed, and of course the ball mount must be corrected.
tag axle drum and hub assembly str8strm Mechanics Corner - Engines, Transmission & More... 13 12-20-2007 02:26 PM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Hub Help frozen chosen Axles 6 05-01-2005 04:55 PM
Hot hub Pahaska Axles 5 04-22-2005 03:29 PM
