Old 06-15-2009, 07:28 PM   #29
1974 Argosy 24
Winston Salem , North Carolina
Originally Posted by Mikethefixit View Post
YUP thats the little bugger. That spring is on the back side of the seal and it holds the seal edges to the spindle and keeps the grease in and the water and dirt out. Hopefully. I have replaced alot of those. Well they were just a smidge larger, BIG TRUCKS ya know. 45 yrs I changed alot of em.
Micheal YA DID GOOD!
thanks for the encouragement. stil can't figure out why the thing gets to hot
michael13 is offline   Reply With Quote
Old 06-15-2009, 07:43 PM   #30
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
1-Bearing adjusted too tight
2-Bearing adjusted too loose
3-Brakes adjusted too tight
4-Brakes not releasing (dragging)
5-One tire taller than the others
6-Trailer not level when being towed
7-The other tire on that side is low on air pressure
Old 06-15-2009, 07:55 PM   #31
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
The spring coming off of the seal generally means it was improperly installed. If the seal was installed wrong maybe the new guy at work assembled that wheel. If so every thing else is suspect. Remove the hub & drum, clean the hub bore with brake clean (airisol can-Auto Zone-3 bucks) till your wife will eat out of it. On the outer side of the hub is a small race, on the inner side of the hub is a big race( race- what the wheel bearing fits into) look at the races, there will be a shoulder under the race that is machined into the hub. the shoulder is what the race is seated to, if there is a gap(use a feeler gauge to check for a gap) between the either race and shoulder that race is not pressed in far enough. If that is the case the bearing will not seat because the race will move inward as pressure is applied. a machine shop can press the race if nessisary. Adios, John
Diesel1 is offline   Reply With Quote
Old 06-16-2009, 01:00 AM   #32
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, when you installed the complete axle assemblies, You had to connect the brake wires; Re-check your wires and connections. Possible that this is the only brake working, therefore it gets hot?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-16-2009, 04:51 AM   #33
1974 Argosy 24
I can hear the brakes on each wheel engaging and tested them by spinning the wheel and applying pressure on the brakes
Old 06-16-2009, 06:17 AM   #34
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
I have never heard of too much grease in a hub.Dave
easyride is offline   Reply With Quote
Old 06-16-2009, 07:24 AM   #35
1974 Argosy 24
look what i found, sorry folks i have to rant a bit , first the spring and now a bent bearing
this is what i found after a thorough cleaning and more time to inspect the bearings
OK all better now
for right now i will take a bearing out of my old axles and replace the bent one
and go for another test drive
Later
Old 06-16-2009, 08:25 AM   #36
Community Organizer
Guido's Avatar
2005 22' Safari
South Chicago , Illinois
OK all better now
Later
"Made in Thailand"?
Fr. Guido
"We have just religion enough to make us hate, but not enough to make us love one another." Jonathan Swift
Guido is offline   Reply With Quote
Old 06-16-2009, 08:31 AM   #37
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Michael, bearings are cheap. Use a new one. The factory should reimburse you anyway.
If too much grease is used, as someone posted on another thread, heat won't dissipate. I guess someone might fill the entire area between the bearings with grease and maybe that would be a problem but I'm just repeating what someone else said somewhere else. Maybe this is how rumors start.
It looks like that's not the problem, though the photo didn't get posted.
Gene
Old 06-16-2009, 12:15 PM   #38
OK all better now
Later
Mike.
Please keep me posted as to the end result answer.
I have directed the office to send you a new bearing and grease seal, today, via UPS, next day air.
I was not aware that you had already talked to Greg yesterday.
Please use caution when removing a hub. They must be pulled straight off. If it is allowed the drag, or catch, on the spindle, the grease seal can be damaged.
Please PM me if you have any other questions.
You can also call our office, if you wish, and ask for Greg. He is the shop foreman.
I may not be instantly available, since I am on vacation in Hawaii.
Old 06-16-2009, 02:46 PM   #39
1974 Argosy 24
Originally Posted by Inland RV Center, In View Post
Mike.
Thanks Andy
so, as i was doubting my skills, i have called a local RV service to check the hub
they agreed to have a look at it first thing in the morning.
as i was pulling into their lot and touching the hubs ....... all of them cool as an ice cube well, as cool as it can get
just to be sure i asked them to double check it- i will be traveling with family, better save than sorry- hopefully tomorrow afternoon
cheers everyone
Old 06-16-2009, 06:02 PM   #40
blacksheep's Avatar
1965 26' Overlander
1962 24' Tradewind
Vincennes , Indiana
Ya done good Michael! My guess is someone dropped that bearing before it was installed in the hub.
And, you can never put too much grease into a hub, it will simply come out the seal. Matter of fact lots of farm implements are designed with a grease fitting in the hub and the recommendation is to pump grease in until it starts to come out the seal. Admittedly, farm implements operate in extremely dirty/dusty conditions which warrant the need for such maintenance. But rest assured, one cannot have too much grease in the hub.
Godspeed,
Trent
TV1: Black Sheep, 2001 Dodge 3500, 800,xxx miles, a few non-stock parts here and there...
TV2: Brownie, 1989 Dodge W250, only 256,000 miles!
TV3: 2004.5 Dodge 3500, 415,000 miles, 6 spd
TV4: 2005 Dodge 3500, 478,000 miles, 4spd auto
"Too much of what I once knew I now know not" Me
blacksheep is offline   Reply With Quote
Old 06-16-2009, 06:51 PM   #41
Master of Universe
Gene's Avatar
And they don't go down the highway at 65 mph which increases heat.
Gene
Old 06-16-2009, 07:52 PM   #42
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
You know, I was looking through this booklet thing that Andy sent along with our new axles and hubs. It's got a diagram of a different hub assembly that includes a zerk. Apparently, you just connect on with the grease gun and pump the thing full. (That'd be a lot easier than the "method" I use.)
Lynn
WBCCI 21043
tag axle drum and hub assembly str8strm Mechanics Corner - Engines, Transmission & More... 13 12-20-2007 02:26 PM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Hub Help frozen chosen Axles 6 05-01-2005 04:55 PM
Hot hub Pahaska Axles 5 04-22-2005 03:29 PM
