Old 06-14-2009, 07:49 PM   #15
1974 Argosy 24
Winston Salem , North Carolina
Thanks , i will try this
and if this is not working, lets dismantle the "%*&%$$*"
michael13 is offline   Reply With Quote
Old 06-15-2009, 09:50 AM   #16
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Michael, there are other threads on wheel bearings and such. Search for them and read them. The advice you have received is correct, but more reading would be helpful.
Gene
Old 06-15-2009, 11:19 AM   #17
1974 Argosy 24
here is the little culprit, after wrestling the drum of i found this, pretty sure it is not supposed to look like this
after calling Inland RV, went to a local RV dealer and got a new grease seal
everything is back together and will go for a test drive this evening.
Thanks to everyone for the good advice
I will keep you posted on how it went
Michael
ID:	82381   Click image for larger version
Old 06-15-2009, 12:12 PM   #18
Master of Universe
Gene's Avatar
Even though I took things apart a month ago, I could be wrong, but I don't think you will find more than 3 springs in there and none of them look anything like that. Two of them should be return springs to bring the shoes to rest after you let up on the brakes. They should be larger in diameter and shorter—maybe 1 1/2" long. The 3rd spring may tension the adjuster, but I was looking for other things at the time. It looks similar to the other two. When you look at brakes, how they work seems pretty obvious.
What you have there looks like something someone left in there. Are the other springs in place?
Of course, the brakes could operate differently on your model, but I think the way drum brakes operate hasn't changed much in generations.
The open question is why would this spring cause overheating?
Here are some pictures of springs, one of which is of a kit and not a particularly good picture, but if you blow up the lower right side, you can see what trailer brake springs look like:
ID:	82385   Click image for larger version
Old 06-15-2009, 12:55 PM   #19
1974 Argosy 24
From what my understanding is, this spring is just behind the back grease seal holding the seal tight
at least this where i found it and the new one has the same spring in place, nice and round of course
Old 06-15-2009, 01:32 PM   #20
Master of Universe
Gene's Avatar
Oh! That's new to me. The few I've worked on have the grease seal held in by friction and you drive it in. Next question—who last worked on the bearings and when? There shouldn't be such a failure on a seal unless it's installed improperly or left in much too long. You are fortunate you caught it now because it could have been a lot worse. Check the bearings and the races to make sure they are ok. Those parts are cheap.
Gene
Old 06-15-2009, 01:56 PM   #21
1974 Argosy 24
Gene
well the axle and the drum was brand new, everything came factory installed to me , i found out during a 20 mile test drive , so i am not sure what went wrong
yup, checked everything and it looked good , so i guess i just caught it in time
Old 06-15-2009, 01:58 PM   #22
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
If that grease seal was that messed up ,is there grease all over the shoes? If so you need new shoes. Dave
easyride is offline   Reply With Quote
Old 06-15-2009, 02:19 PM   #23
1974 Argosy 24
No grease on the shoes, i wiped/cleaned everything with mineral spirits, just to be sure, but when i opened it up is was clean
Old 06-15-2009, 05:51 PM   #24
1974 Argosy 24
Still hot....... i do think even more than before
Do i have to let it cool down before opening it up???????
To much grease maybe ????????
or could it be that i have the wheel to loose????????? i read the thread about the bearing adjustment ?
any help is aprechiated
Old 06-15-2009, 06:07 PM   #25
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It is possible that a piece of the seal spring may have been eaten by the bearing. I would inspect the bearing carefully as well as the race.
Richard
Old 06-15-2009, 06:15 PM   #26
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Might be your controller
If the wheels spin freely when off the ground, and the bearings are greased and adjusted properly, the tires are inflated properly, there should be no excessive heat build-up.
Have you given the wheels a spin while connected to your tow vehicle?
Could there be something wrong with your brake controller? It happened to me a couple of years ago. Started off one morning, got on the highway and the trailer brakes came on all by themselves. I had to disconnect the trailer electrical to get off the highway. I replaced the controller and the problem went away.
Old 06-15-2009, 06:26 PM   #27
1974 Argosy 24
The wheels spin freely when connected to the TW and it seems that the controller works fine ( brand new) and stopes the wheels when the brakes are engaged
since i have no experience it could be that i went a bit overboard with the grease
and need to adjust the bearings
Old 06-15-2009, 06:59 PM   #28
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
YUP thats the little bugger. That spring is on the back side of the seal and it holds the seal edges to the spindle and keeps the grease in and the water and dirt out. Hopefully. I have replaced alot of those. Well they were just a smidge larger, BIG TRUCKS ya know. 45 yrs I changed alot of em.
Micheal YA DID GOOD!
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
tag axle drum and hub assembly str8strm Mechanics Corner - Engines, Transmission & More... 13 12-20-2007 02:26 PM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Hub Help frozen chosen Axles 6 05-01-2005 04:55 PM
Hot hub Pahaska Axles 5 04-22-2005 03:29 PM
