Old 05-19-2009, 08:22 AM   #1
1974 Argosy 24
Winston Salem , North Carolina
hooking up brakes
Greetings everyone,
My brand new axles, for my 73 Agrosy, from Inland RV will be delivered tomorrow, cant wait
i have read on how to install them , which seems to be not that hard
the only thing i am unsure about is how to hook up the new breaks.
The trailer does not seem to have any color coding on the wires
could anyone help with this
Michael
michael13 is offline   Reply With Quote
Old 05-19-2009, 08:25 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Way to go on the axle replacement. It dosent matter which way you hook up the wires.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 05-19-2009, 08:54 AM   #3
Originally Posted by michael13 View Post
Greetings everyone,
Michael
Electric brakes are "not" polarized.
It does not matter which color goes to which color.
Old 05-19-2009, 08:58 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
The DC magnets will work with the wires connected either way.
Check the alignment of the axles when you are done. I use an 8 ft florescent light bulb laid across the edges of the tires at the center line. The bulb should touch each side of each of the tires. Anything greater than an 1/8 in. will result in excess tire wear.
2004 Excursion 4x4
Old 05-19-2009, 09:07 AM   #5
Howie.
The bulb is a good tool.
The bulb should only touch the "rear" edge of the tires, for perfect alignment.
The front of each tire should have about 1/8 clearance from the bulb.
Thats the specs on a new Henschen axle.
Old 05-19-2009, 10:05 AM   #6
1974 Argosy 24
could yo guy's explain the tire alignment one more time
Old 05-19-2009, 11:45 AM   #7
HowieE's Avatar
Images: 12
If you have a long florescent light bulb, about the straightest thing on earth, and place it against the edge of the tires so it passes through the center of each tire the bulb will show any misalignment. Ideally the bulb should touch the rear edge of each tire and have about an zero to 1/8 in. gag between the tire and the bulb at the front edge of the tire. If you see any gap other than this the axles are out of alignment and will effect tire wear.
Make sure when you do this that there are not a raised point on the tire one or more of the tires, style numbers or letters.
The nature of assembly for these axles dose not lend itself to accuracy and corrective alignment is often required.
This test does not address camber angle, but camber angle is not the issue on a trailer that it is on a steering axle.
My trailer as delivered from the factor would tare up a set of tires in less than 5,000 miles. After corrective alignment I ran them for over 100,000 miles before replacement.
If alignment is required you will have to find a Truck axle shop. Do not take the trailer to JC because they have no idea how to do this. Been there did that.
2004 Excursion 4x4
Old 05-19-2009, 01:36 PM   #8
1974 Argosy 24
Thanks, this helps a lot
as soon as the axles are in i will post a few pics from the process.
this could take a few days.
I am still waiting on the shocks , Andy mentioned that they are on back order.
lets wait and see
Old 05-19-2009, 01:38 PM   #9
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
If I am reading this right it should have a toe out of 1/16 " ? Is that correct? Dave
easyride is offline   Reply With Quote
Old 05-19-2009, 01:51 PM   #10
NO NO.
It's a toe in of 1/16 inch.
Old 05-19-2009, 02:09 PM   #11
lets wait and see
HEY HEY HEY
GREAT NEWS
Airstream has shipped our load of shocks via motor freight, since there are so many of them.
They should arrive by the 27th.
We will immediately fill all the shock back orders at that time.
Old 05-19-2009, 04:54 PM   #12
1974 Argosy 24
Originally Posted by Inland RV Center, In View Post
HEY HEY HEY
GREAT NEWS
That is great news, getting ready to muscle the new axles in
Oh, and thank yo to everyone that has replied to my original thread
Michael
Need help hooking up gas stove Jephellis LP Gas, Piping, Tanks & Regulators 3 07-08-2008 07:54 AM
When hooking up to electric which amp would we use?? 30, 50? ckelly617 All Argosy Trailers 2 03-15-2008 12:12 AM
Midwest Hooking up Solar Panel Jurgena Boondocking 3 06-22-2007 04:39 PM
hooking up new radio powd Audio, Video & TV 15 07-20-2004 08:37 PM
