Old 10-18-2002, 08:45 PM   #1
hex
hex's Avatar
Question Henschen Axles
Does Henschen have a website? or even a telephone number?
How about a customer service dept?
Where are they headquartered.
I exhausted Google to no avail.
hex is offline   Reply With Quote
Old 10-18-2002, 09:17 PM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Henschen Industrial
522 N. Main St.
P.O. Drawer "T"
Jackson Center, OH 45334
tel: (513) 596-6125
tax: (513) 596-6809
BobbyW is offline   Reply With Quote
Old 10-18-2002, 09:34 PM   #3
JW84345's Avatar
1969 27' Overlander
, Michigan
First you drive into town (Jackson Center)
JW84345 is offline   Reply With Quote
Old 10-18-2002, 09:37 PM   #4
JW84345's Avatar
1969 27' Overlander
, Michigan
Where are they headquartered #2
Past the Airstream plant. Stop in and take the tour!
Old 10-18-2002, 09:39 PM   #5
JW84345's Avatar
1969 27' Overlander
, Michigan
Where are they headquartered #3
You take a left on one of the side streets past the plant and there it is!
Old 10-18-2002, 09:59 PM   #6
Silver Bullet's Avatar
Ya reckin' that tractor has the tow rating for an AS??? Sorry, couldn't resist! Oscar
Silver Bullet is offline   Reply With Quote
Old 10-19-2002, 02:42 PM   #7
Henschen has a new web site under construction. May take another 6-8 weeks to complete.
However, it will be directed to other O.E.M. manufacturers, and not the retail market.
inlandrv.com
airstreamparts.com
Old 10-19-2002, 03:29 PM   #8
hex
hex's Avatar
Question
Thanks for the tour I'm calling my travel agent asap!
Was / Is Henschen owned in whole or part by Airstream/Thor?
Seems co-incidental both in Jackson Center.
I have read that they rebuild their axles, unless there is rust present.What is the cost approx. of a rebuild?
Are we talking external rust or internal?
No used axle more than 6 weeks old is completely rust-free in my opinion.So how much rust is enough to cause un-rebuildability?
Is there a way to determine build date of the axle?
i.e a 74 Airstream was very likely built in 73, Did Henschen change the design on Jan.74 or with the 74 models come-out-datecirca Sept/Oct 73?
Finally does any other axle manuf. use the rubber rod system and
Is there an alternate brand ever recommended or used under an airstream trailer?
Old 10-19-2002, 03:43 PM   #9
BobbyW's Avatar
Houston , Texas
http://www.dexteraxle.com
http://www.al-ko.com/vehicle/index.html
I tried chasing down who owned who back in June/02. Thor (Airstream) does not own Henschen any longer.
http://www.airforums.com/forum...highlight=axle
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
Old 10-19-2002, 10:43 PM   #10
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Dexter Axles
My International has Dexter axles according to the parts catalog and according to the tags on the axles. The sheet that came with the trailer says they areHenschen and gives a Henschen number. I'm guessing they are both the same company at some level.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 10-21-2002, 07:35 AM   #11
Chas's Avatar
Images: 22
Henschen??
The Henschen axle I got from Inland RV had Dexter brakes on it so go figure. I am not sure Henschen will sell direct to the end user. I had tried and gave up. As a business owner myself I can understand why. At any rate I felt better getting it through Inland so if anything wasn't right I could give Andy some grief as he seems to handle it pretty well.
Former Airstreamer
Chas is offline   Reply With Quote
Old 11-12-2002, 04:38 PM   #12
2000 27' Safari
Wappapello , Missouri
I dealt directly with Henchen back in Mar. of 2000 to have the axles of my 1997 Safari 25 reconditioned and upgraded. The cost was approx. $100 apiece. They would have sold me new axles for approx. $200 apiece.
I delivered the axles directly to their plant in the morning and picked them up that evening (5:00pm).
Bill Howell
Wappapello, Mo.
2000 Safari 27
2005 Dodge Ram 2500 Diesel
WBCCI #2526
wyhjr is offline   Reply With Quote
Old 11-12-2002, 06:50 PM   #13
That's exactly the reason Henschen made a change.
They "LOST" big money on every one they sold or rebuilt at those prices.
Their parent company put an end to it, quickly as they are an "OEM" supplier, only. Henchen's new web site, will clearly point that out.
"O. E. M." only.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Old 11-12-2002, 08:32 PM   #14
Well Andy....
I'm going to put their "OEM only" attitude to the test! If they can't supply me with the same bracket system on my '62 Overlander without modifications, then the OEM talk is out the door. That also means "at no extra cost". The bracket system is simpler than todays system of mounting. Oscar
Torsion axles Silvertwinkie Axles 4 01-29-2004 08:18 AM
Are our axles undersized ? Mike B Axles 5 09-19-2003 06:21 AM
New Axles for '76 Argosy 26 76Argosy Axles 2 07-07-2003 08:31 PM
Henschen Axle Plant Tour Inland RV Center, In Axles 0 09-22-2002 02:04 PM
Motor Home Tag Axles - winner General Motorhome Topics 0 05-25-2002 04:56 AM
