Old 11-13-2002, 12:13 AM   #15
overlander
Guest
Posts: n/a
well..... is it possable to get parts from Henschen so you can rebuild your own axles? so you can just replace the parts that are wore out........just asking?
i realize you may need special tools, i havn't tore one apart or anything. can you take one apart and put it back togeather?
Old 11-13-2002, 08:07 AM   #16
Silver Bullet.
Current style axles will not fit a 62, without some modifications, which, if done, make the axle attachment superior to the original.
Making one axle of a specific outdated design is not what "OEM" suppliers have in mind. Your requirement does not fit the "OEM" category.
No need to "test" Henschen, as they will not accomodate your request.
I am not aware of any axle that will "exactly" fit your 62.
If you do not wish to modify the axle attachments, then perhaps you should call Southwest Wheel.
They make a "universal""universal" axle, that one can tinker with and "maybe" have something that won't too soon, fall apart.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Old 11-13-2002, 08:12 AM   #17
Overlander.
My 37 plus years with the Airstream product, is inadequate for me to consider myself technically qualified to answer your axle questions.
Perhaps some other challenger can help you.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Old 11-14-2002, 07:48 AM   #18
Silver Bullet's Avatar
That figures....
Andy,
"Superior" is a relative term, I mean, the axles have been mounted for 40 yrs without any problems! No sense in in using Southwest Wheel, if I'm going to have to "tinker" I may as well do it with the appropriate product. Can't blame me for being a tad miffed, what would have been an easy weekend job (dismount and remount) will now take more time and surely more expense for new bracketry. Guess I'm going to have to get under a newer model and see what all will be involved with replacement parts. Oscar
Silver Bullet is offline   Reply With Quote
Old 11-14-2002, 08:28 AM   #19
Oscar.
Adding the "axle mounting plates" to your Airstream, is not a big deal, nor is it that expensive.
Removing two axles, installing new axle mounting plates, installing the new axles, with shocks, takes less than 8 man hours.
When it's done, you can sit back in your lawn chair and enjoy the new look, and profile. Adding a cool one, will add to the smile, and pleasure.
Your Airstream will love you for it.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Old 12-29-2002, 10:12 PM   #20
Forrest's Avatar
1986 32' Excella
Aurora , Colorado
Images: 21
Unhappy
I called Henchen direct from a number I found on the Internet. The man I talked to wasn't too pleased to hear from me. I imagine that with all the Airstreamers rebuilding vintage units the man has had so many calls that it distracts him from his regular job. I told him he couldn't blame me for trying! Afterall the prices I'm reading that some postings say they got their axles for direct from the factory are quite the savings. I finally just bit the bullet and ordered mine from Inland.
The install was not as hard as I thought it would be, but if you do it alone it will take more than the 8 hours Andy says (unless you're a professional mechanic). I was a little distressed Andy that the axle didn't arrive on a pallet. It made unloading it from the Yellow Freight truck unwieldy and it arrived with minor damage (mostly to the dust caps on the ends of the axle). One cap was crushed and I had to hammer it back into shape. For the money it ought to be better prepared for shipment other than having duct tape wrapped around it!
Forrest is offline   Reply With Quote
Old 12-30-2002, 07:41 AM   #21
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Interesting Corporation Stuff
It is always interesting to dig through the internet and see who owns who.
What started me digging is the fact that the "yellow sheet" for my 2003 International indicates that the axle is Henschen and gives a whioe string of Henschen part numbers; however, when I looked under the trailer, I found that the axle had Dexter shipping tags. A further look at the parts manual shows that the axle is truly a Dexter axle.
My first thought was that I would find the same corporate ownership somewhere up the line. After all, the axles are virtually identical in design and manufacture.
A look at the Henschen site shows that it is a "Lakin General" company. Lakin General is a family-owned Chicago company. A look at the Dexter site shows that Dexter is owned by Tomkins of London, England and has never had any commonality with Henschen.
A search for Lakin General shows that Henschen must be something of a stepchild. Their main focus, it seems, is:
Welcome to Tires, Tyres and More TIRES!! Main Menu | Industry Directory: Lakin General, Inc. Lakin General is a company dedicated to the recycling of car and truck tires. Tires with usable tread can be resold.
I did find one or two hits identifying them as other than a tire recycler, such as:
Jan. 23, 2001 Machine parts maker eyes West Side location Daley plan would help company relocate, hire 40 people
and this link which doesn't mention Henschen:
http://w4.cityofchicago.org/Mayor/20...yprograms.html
John W. Irwin
WBCCI #9632
Old 01-02-2003, 02:15 PM   #22
Rick T's Avatar
1967 17' Caravel
Bozeman , Montana
Forrest:
I would suggest you take off your hubs and inspect the bearings and seals, at least on the side that had the dented dust cap. Hereís my new axle experience: When Yellow Freight delivered my axle one of the dust caps was gone. I too had to have plates welded to the frame because the axle brackets were taller. Everything went well until I removed the brake drums and backing plates in order to drill holes into the aft axle brackets. At the curb side, (the same side missing the dust cap), I discovered the inside grease seal spring was pinched under the bearing. The bearing was shoved tight against the spindle so hard I had to rent a puller to remove it. I replaced both the seal and the bearing (just in case). Because I had to extend the frame and drill new holes I discovered the problem which could have caused early bearing failure. The only thing I can figure is the axle got dropped in shipment. I agree, Henschen should do more to protect the axles from shipping damage. The duct tape around the lug nuts just doesnít do it. In my case, now I wonder if any unknown damage was done. If it was dropped hard did it affect alignment, weaken the spindle weld, or? Guess Iíll have to wait until summer, put some miles on the trailer, then inspect the curbside tire for abnormal wear.
Rick T
Rick T is offline   Reply With Quote
Old 01-02-2003, 02:31 PM   #23
hex
hex's Avatar
Question More fabrication questions
Rick we have read about shock mount flanges having to be welded to the mounting bracket on the axle itself to attach the lower shock.
Do I understand that you had to add on to the axle mounting plate which is part of the trailer chassis?
Was the additional part furnished with the axle/s ?
Were you made aware of the alteration would be needed when ordering the axles?
Were there concise instructions furnished?
Did your shock absorbers mount without further alteration?
Oh and were the bearings and seals and retainer spring available locally?
Any chance of photos before, during, and/or after?
Thanks in advance.
hex is offline   Reply With Quote
Old 01-02-2003, 10:17 PM   #24
axles
What the heck is O.E.M. anyway? I hate it when people assume everyone knows all this stuff - please remember that there are some real novices reading these posts, hoping to get some good info for their old AS's. Thanks folks.
smallfry is offline   Reply With Quote
Old 01-02-2003, 11:46 PM   #25
Smallfry,
If I'm not mistakin' ( and I might be, hey it's almost 12.01AM here ) OEM means "Originally Equipt by Manufacturer" give or take. Don't feel like you're left in the dark on certain topics or wording, just ask. ALL of us here have asked questions, feeling a tad overwhelmed a time or two (or three or four)
Seeing your profile, OEM is "out the door". NOS (New Old Stock) is what you will be getting used to seeing. I'm in the same boat with a '62. Oscar
Old 01-03-2003, 10:13 AM   #26
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Alphabet soup
It's the SAE (Society of Automotive Engineers) that developed the OEM (Original Equpiment Manufacturer) standards. However when OEM parts become old enough and sit on a shelf, the parts become NOS (New Old Stock) Or an AIM (Aftermarket Industry Manufacturer) designs parts to replace the OEM parts cause they has found a niche. Not to be confused with a notch!
And that last thing you want to do is be stuck in a notch.
>>>>>>>>>>>ACTION = Anything Concocted To Impress Off shore Natives
Old 01-03-2003, 01:42 PM   #27
OEM and others
Ok I get it(OEM) and thanks everyone for the information. I guess with my old AS, it'll be NOS (or was it ONS) at best, huh. Gads, there's lots to learn. I now have Bubbles stripped down to bare plywood with just one wall hung overhead cabinet and a couple of side lights to remove. The little water tank is out, the plumbing is just a couple of plastic pipes sticking up through the floor (that can't be original, right? plastic pipe?), and there's a big hole in the middle of it all where the little floor furnace was. All the cabinets and the bed supports are gone and I think that was the main source of the mildew smell. I spread Arm & Hammer cat litter all over the floor to soak up any residual odors, but now I have to be sure to close the door or my 3 cats with refurbish the odors for me.
I have also engaged the services of a "small spaces" architect to help me work up a design - this should be fun...maybe. He did a neat design for a friend who has a tiny 400 sq ft coffee shop in town so I'll let you all know how that progresses.
Last time i worked with an architect, it was a major house re-model and it was like having teeth pulled - the design process really makes you focus and think about what you really, really want and that's tough.
Sorry if I came off grumpy before but that was because I was grumpy that day, actually. jw
Old 01-03-2003, 04:53 PM   #28
Rick T's Avatar
1967 17' Caravel
Bozeman , Montana
Hex: I did have to extend the mounting plate on the trailer chassis to attach the new axle. The new one had a bracket extension approximately one inch higher than my old axle, (the width of the brackets was the same). The new axle only partially fit into the existing chassis frame channel. Prior to buying the axle Andy (Inland) told me that Caravels are different, often assembled with left over parts from earlier year/larger trailers so I knew I could be in for a few surprises. When I told him about the new axle not fitting into the chassis channel he explained that when my trailer was made the axles were hand built, also not many trailers like mine were made. He explained that all the new axles come with the taller bracket. He told me the solution was to extend the chassis mounting plate downward with 3/16í steel. Looking back at the project the chassis frame extension was an unanticipated inconvenience but I now have more clearance. I ordered the axle with a 30 degree tortion bar angle rather than the regular 22.5, so with the extra inch the axle bracket added I have more clearance yet. Also, the weight rating went from 3,000 lbs to 3,500. The steel cost less than $5.00., a friend was nice enough to bring his welder and do the work, so no cost to speak of. Shock mounts: I donít have them welded on yet. They were shipped loose because apparently the exact mounting location on the tortion arm is unknown. Now that the axle is bolted on securely I will tow to another friendís shop (who wants the old axle in trade) and have him do that work. Andy suggested positioning the shock half way between full extension and compression to determine the proper mount position. Iím not quite sure yet whether the shock should be positioned exactly vertical or if it matters. I think Iíll ask some questions before welding happens. It looks like Forrrest has some shock mounting suggestions on another thread so Iíll read his posts to see if the question is answered there. The bearings and seals were available at NAPA, just took in the old ones & they matched numbers. Hope this answers your questions. Here are a few photos.
Rick T
Torsion axles Silvertwinkie Axles 4 01-29-2004 08:18 AM
Are our axles undersized ? Mike B Axles 5 09-19-2003 06:21 AM
New Axles for '76 Argosy 26 76Argosy Axles 2 07-07-2003 08:31 PM
Henschen Axle Plant Tour Inland RV Center, In Axles 0 09-22-2002 02:04 PM
Motor Home Tag Axles - winner General Motorhome Topics 0 05-25-2002 04:56 AM
