Old 07-12-2015, 07:06 AM   #1
1965 26' Overlander
Woodbine , Georgia
Help with axle replacement
I ordered new axles through Inland RV for my 1965 Overlander. They have arrived and everything matches up except for the bracket. The bracket is off set on the axle with a longer portion on one side of the axle and a shorter portion on the opposite side of the axle. On the old axles with the swing arms pointed rearward, the longer portion of the bracket was in front of the axle. On the new axles the longer portion of the bracket is rear of the axle. Inland RV's instructions said to install the rear bolt and to drill 3 new bolt holes for the front. If I align the rear bolt holes on frame and axle, it moves the wheels forward 6-8 inches which won't work. Does it hurt anything to mount the axle in the slot in the frame and drill new holes? This would put the longer portion of the bracket rear of the axle. Does this rear facing bracket affect the strength of the installation? I am attacing pictures. Sorry for the long post.Click image for larger version
gamakai is offline   Reply With Quote
Old 07-12-2015, 07:48 AM   #2
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
When I installed axles on my 65 over lander, I had to drill new holes,& increase depth on notches to get axles to rest against frame rails. AS originally did not have them against rails on mine,so all of the weight was resting on frame brackets, not good! It was a major PIA! If that wasn't bad enough, I also had to extend mounting plates& put spacers to get trailer to sit higher , because I ordered 22.5 degrees axles. Once on ground it sat lower than it did before axle swap! Good luck!
Cochese is offline   Reply With Quote
Old 07-12-2015, 09:15 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Imo, get the wheels where they should go and drill all new holes if needed.
Old 07-12-2015, 09:37 AM   #4
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Tell us about Inland's response. How helpful have they been?
Old 07-12-2015, 02:14 PM   #5
1989 35' Argosy 5th Wheel
1979 rgosy 27
Danville , Vermont
IMO. Get the axles where they go and drill new holes. I agree. The bracket may not be the right one. Dexter only offers a side mount and a top mount bracket, with an option on the top mount for 1" lift. I am not familiar with your specific model and I cannot tell much from the picture. If you do attempt to place and drill new holes, be very precise. This is an easy place to intorduce an alignment problem when you think you are finished.
fordfarmer is offline   Reply With Quote
Old 07-12-2015, 02:40 PM   #6
enived2's Avatar
1967 20' Globetrotter
Englewood , Colorado
Images: 12
Had the same problem with a globe trotter axle I bought from inland. Once the sale has gone through they will not give advice. Bought $2400 of merchandise including a black tank and couldn't get any help. He was always in the back and would not return calls. Measure and redrill holes where they are needed as was mentioned. Found out afterwords that if you take your axle's to a trailer shop they can match them and save on shipping from California
Www.projectmidge.wordpress.com
enived2 is offline   Reply With Quote
Old 07-12-2015, 02:46 PM   #7
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I had a similar problem almost 10 years ago when I ordered axles for our '64 Overlander. (See this thread) Axis sent me a new pair of axles, one of which had to be replaced because the drop angle was wrong on one end. They had the old axles at the factory to copy so they should have got it right the first time.
Then about 4 years later I ordered axles through Colin Hyde for our '74 Sovereign and had the same problem, which again resulted in Axis shipping two new axles. During one of my conversations with Axis I was told that some Airstreams have the longer arm facing to the front and some have it facing to the rear.
I would talk to Andy at Inland to make sure you have the right axles before you try to install them.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 07-12-2015, 04:08 PM   #8
Life long Airstreamer
korgen's Avatar
1966 24' Tradewind
Wilsonville , Oregon
I just want to give a shout out to Colin Hyde Restorations in the New York area who I ordered my axles through. I didn't have to take any measurements, I just told him the year and model and he knew exactly what I needed. That gave me a lot of peace of mind. He has ordered hundreds of torsion axles for Airstreamers and spent some time searching out the cheapest shipping for me. They fit perfectly though I did have to drill some holes.
korgen is offline   Reply With Quote
Old 07-12-2015, 04:23 PM   #9
1964 26' Overlander
Milton , ON
And just to be clear, it was Axis's mistakes that led to my axle woes, not Colin's.
Grant Davidson
Milton, ON
1946 Spartan Manor
1964 Overlander
1974 Sovereign
TAC ON-5
Old 07-13-2015, 05:48 AM   #10
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Originally Posted by gamakai View Post
I ordered new axles through Inland RV for my 1965 Overlander. They have arrived and everything matches up except for the bracket. The bracket is off set on the axle with a longer portion on one side of the axle and a shorter portion on the opposite side of the axle. On the old axles with the swing arms pointed rearward, the longer portion of the bracket was in front of the axle. On the new axles the longer portion of the bracket is rear of the axle. Inland RV's instructions said to install the rear bolt and to drill 3 new bolt holes for the front. If I align the rear bolt holes on frame and axle, it moves the wheels forward 6-8 inches which won't work. Does it hurt anything to mount the axle in the slot in the frame and drill new holes? This would put the longer portion of the bracket rear of the axle. Does this rear facing bracket affect the strength of the installation? I am attacing pictures. Sorry for the long post.Attachment 242735
The brackets from 1965 are different from those currently made. In a nutshell, the square tube slides into the cut out of the axle mounting plate on the trailer. Depending on the new axles you have, you may have to enlarge the slot on the trailer for the tube to fit. You will have to do some drilling.
I'm sure a call to the vendor of the axles would be helpful.
Good luck.
Lance
Top is offline   Reply With Quote
Old 07-14-2015, 02:14 PM   #11
1963 22' Safari
Vail , Arizona
New axle from Inland RV
I did this installation a few months ago on my 1966 Safari 22 ft single axle trailer.
The main difference between the old axle and the new one is the orientation of the shock absorber. On my original axle, the shock was in a near horizontal orientation. The new one is in a vertical orientation.
For mounting the axle itself to the frame, I did grind out the opening in the rails slightly to allow it to seat on the frame members; I drilled all new axle mounting holes. I then ground off the welds holding the shock mount brackets and removed them. I relocated them to mate with the new shocks. The new shocks have a shorter travel. I positioned the frame so that the axle torsion spring was relaxed for max shock travel. I bolted the brackets in place to allow max shock stroke. Later I had the brackets welded in place.
If you need/want more detail, email me at Morganobenn@gmail.com.
morganobenn is offline   Reply With Quote
Old 07-24-2015, 01:40 PM   #12
1965 26' Overlander
Woodbine , Georgia
Axles replaced
First, thanks to all who responded--I was really nervous about starting this project. Several people asked about Andy's cooperation-I called him on a Friday and it was Tuesday AM when he got back to me. His info was extremely helpful but I regretted losing the weekend to work. Dexter reversed the brackets on my axles but Andy said they would work fine. I had to enlarge the cutouts in the frame from 23/4" to 3". I drilled new holes and inserted the bolts. I am so pleased with the ease of install. 1st axle took 4 1/2 hours--2nd axle took 2 1/2 hours. Thanks again for your advice--I can't express how much it helped.
Old 07-24-2015, 07:12 PM   #13
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Glad we could help you brother!
Godspeed!
Old 07-24-2015, 08:26 PM   #14
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I got Axis axles from Colin 5 or 6 years ago when I redid my Trade Wind. I had to drill new holes. Be very careful when you drill the new mounting holes. It takes a 1/2 inch drill and if I recall a 5/8 drill bit. When the bit breaks thru the mounting bracket it tends to grab. It will twist the drill out of your hand and it might even break your wrist if you are not careful. A big drill has lots of torque so be careful.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
'90 Limited 34' (Axle and shock replacement) URGENT HELP PLEASE Elf1 Axles 2 02-21-2010 08:20 AM
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 04:15 AM
