Old 07-26-2015, 10:27 AM   #29
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Yes, it's a high quality metal cutting hole saw, they are available thru McMaster-Carr under hole saws. They cut a very round hole. Unibits are also very handy for opening up holes, but when a Unibit is used to open up two misaligned holes you remove material from both surfaces. With a Rotobroach you will only remove material from the aft surface. Either approach works, it doesn't really matter which method or tool is used, you just want to get the job done in the most efficient manner available to you.
Unlike most of the members here, I didn't have to go out and buy a bunch of expensive special tooling to work on my Airstream as I already had them for my day to day pay the mortgage job.
Old 07-26-2015, 10:57 AM   #30
Aerowood's Avatar
Arvada , Colorado
Here ya go
http://www.mcmaster.com/#4093a81/=y809ql
McMaster-Carr
Old 07-26-2015, 02:46 PM   #31
Baltimore , Maryland
thank you for the links but I ordered a set first thing this morning. I only need a half of an excuse to buy a new tool...
Old 12-17-2015, 09:49 AM   #32
1973 23' Safari
1970 27' Overlander
Boerne , Texas
My new axles are slightly wider than the old ones. Any suggestions on how to widen the notch on the frame? have the welder burn it? grind it? Cut with a cut-off wheel?
Greg
Greg1410 is offline   Reply With Quote
Old 12-17-2015, 12:38 PM   #33
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I assume your referring to the axle tubes. I have used an angle grinder to do this job in the past.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 12-17-2015, 08:40 PM   #34
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
I recently did this using a reciprocating saw with metal blade and then grinder to finish up. Just make sure you modify the rear of each notch. Also a good idea to pick a constant point somewhere and check the finished job for squareness and alignment.
youngpeck is offline   Reply With Quote
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
'90 Limited 34' (Axle and shock replacement) URGENT HELP PLEASE Elf1 Axles 2 02-21-2010 08:20 AM
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 04:15 AM
