Old 07-24-2015, 11:01 PM   #15
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Leave that bit a little loose in the chuck,,,
It will suck when it slips, but this is better than getting twisted up by a drill.
#JustSayin...
Old 07-24-2015, 11:12 PM   #16
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I just used a 5/8 Roto Brooch or sometimes called a Blair Cutter in a 3/8 phnumatic drill, real easy it only took a few minutes, even if you are only drilling out a crescent shape to line up the holes
Old 07-25-2015, 06:56 AM   #17
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Best money I've ever spent on cutting tools.
A few years ago I took Kip's advice and bought the Rotabroach cutting kit. It makes cutting 5/8" holes in steel a non issue.
The first time I installed axles on my '72 Ambassador, (yes I have installed axles on her twice) I used a 1/2" drill and a big ol' 5/8" drill bit. I got it done, but broke a few bits along the way and nearly broke my wrist.
I would recommend anyone changing axles to get a set of Blair Rotabroach cutters. It is $63 well spent.
Lance
Top is offline   Reply With Quote
Old 07-25-2015, 07:24 AM   #18
Baltimore , Maryland
Originally Posted by korgen View Post
I just want to give a shout out to Colin Hyde Restorations in the New York area who I ordered my axles through. I didn't have to take any measurements, I just told him the year and model and he knew exactly what I needed. That gave me a lot of peace of mind. He has ordered hundreds of torsion axles for Airstreamers and spent some time searching out the cheapest shipping for me. They fit perfectly though I did have to drill some holes.
There are only three sizes. Tell me the year and I can tell you the size. Axles are treated as such a mystery, they are not. The only thing that varies is the carrying capacities.
Old 07-25-2015, 07:28 AM   #19
a step bit will drill the hole in 30 seconds or less...
Old 07-25-2015, 07:31 AM   #20
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
A Rotabroach will drill it in 20 seconds or less.
Lance
Old 07-25-2015, 07:33 AM   #21
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
If you would give a part number for each size and list the models that they fit it would be a great reference.
Alan
Old 07-25-2015, 07:54 AM   #22
A part number? When one orders you give measurements. Airstream axles are completely unique and used only by them. The bracket to bracket measurement is needed, hub face to hub face measurement. How many pounds it carries, Reverse brackets. I always select easy lube bearings and electric brakes. I also only do 22.5 degrees down. My shop does not do the high rider 4x4 look. You also need to know low profile or high profile bracket. It is very easy. Even though there are just three sizes, I always verify with a tape measure. Some times, someone thinking they know better, alters something. They might have ordered just by giving a serial number. The person on the other end automatically gives them low profile and they needed high profile, they then go in and cut the notch so the axle sits against the frame rail. It happens often. Sometimes they order too small and the mounting plate was bent in and shimmed to make it work.
btw, if you order #11 brakes, you are opening up the mounting notch no matter what. Axles over 4000# are all 3" tube, not the 2 3/4" used previously. To not have to cut out you must go with #10 drums.
I know you requested I list the sizes. I am not going to do that. As soon as I do, someone who has done one axle job will straighten me out. As a professional who does this every week, I tire of being straightened out by people who do this for a hobby. I swapped four axles last week alone. One of the axles was a welded on axle on a 1961. It required major surgery and fabricating two axle mounting plates. It broke my person record for longest axle swap, 18 hours total.
Old 07-25-2015, 12:01 PM   #23
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Thanks!
I'm just trying to learn what I can.
I've studied the measurement sheets the manufacturers have on their websites. I know I would have to provide those. I understand different load capacities, different types of brakes, down angles, etc.
What does reversed brackets mean? And is this something special for Airstreams?
Will you elaborate what you meant by "only three sizes"? Is it the combinations of different measurements between brackets and/or hub face?
Alan
Old 07-25-2015, 12:05 PM   #24
Aerowood's Avatar
Arvada , Colorado
When I find that stepped Roto Brooch I will be able to drill the holes in 15 seconds or less
Old 07-25-2015, 12:22 PM   #25
Aerowood's Avatar
Arvada , Colorado
For those that want to order there own axles the procedures for measuring are really pretty straight forward as outlined in the Dexter site. Just remember to order reverse angle mounting brackets. All this means is the mounts are just welded on reverse from the way Dexter welds on the mount angles in their stock configuration
If you order from your local Dexter dealer in your area ( mine is Redneck Trailer Supply) then you do not have to pay for shipping.
Of all the things I've done on my GT this ranks very high in the easy and fast category. Basically what I'm saying here is don't over complicate it
Old 07-26-2015, 02:57 AM   #26
Originally Posted by A W Warn View Post
Thanks!
Bracket to braket measurement is the same as outside of frame rail to outside of frame rail. The frame size does not change with every trailer, it is consistent. Therefore the axles sizes are fairly consistent also.
Old 07-26-2015, 05:39 AM   #27
So, this Rotobroach... it is a metal cutting hole saw? Is that what I am gathering?
what makes it cut better and faster? Is it the bit or the tool or both. You guys found my weakness for a new tool...
Old 07-26-2015, 10:21 AM   #28
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Get it.
Blair Equipment 11090N Rotabroach Cutter Kit - Hole Saws - Amazon.com
Lance
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
'90 Limited 34' (Axle and shock replacement) URGENT HELP PLEASE Elf1 Axles 2 02-21-2010 08:20 AM
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 04:15 AM
