Old 01-27-2009, 09:12 AM   #15
mikmilr's Avatar
1964 24' Tradewind
Swoope , Virginia
Originally Posted by Inland RV Center, In View Post
The wheel alignment specs, for all Argosy and Airstream trailers, is as follows.
Toe in, each side 1/16 inch
Toe in, tolerance 1/16 inch plus or minus
Camber each side 3/4 degrees positive
Camber tolerance 3/4 degrees plus or minus
Does't this mean that 0 toe and 0 camber are within specs?
Mike
mikmilr is offline   Reply With Quote
Old 01-27-2009, 09:17 AM   #16
Mike
Yes, but that's at the limit.
Old 01-27-2009, 09:19 AM   #17
mikmilr's Avatar
1964 24' Tradewind
Swoope , Virginia
Thanks Andy,
Mike
Old 01-27-2009, 10:34 AM   #18
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The slight amount of toe in allows for axle and tire flex when moving down the road. When the trailer is moving forward the axle (or suspension in other vehicles) will spead (ever so slightly) so the tires will point to the outside. If the toe is set to inward slightly, (toe in) the spread will create a zero toe and there will be no adverse tire wear. At least that is the goal.
So a unit with lots of use (and I consider 30 years to be lots) with no adverse tire wear I would count my blessings and move on to something else that is visabily wearing.
BTW the same holds true for camber, however the issue there is loading of the unit and the dynamic forces applied when this load is towed.
>>>>>>>>>>>Action
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Old axle vs New axle feedback . . . GetOutDoors Axles 21 08-09-2007 01:59 PM
Does this look like I will need a new Axle? kneal Axles 21 01-22-2007 04:51 PM
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 04:15 AM
