Old 06-03-2010, 11:03 AM   #1
funkill's Avatar
reno , NV
Images: 27
HELP please!! Axle on wrong?
Oh my.... I am sitting on the street trying to replace the CURB side backing plate on my aft axle. Inland RV sent me a new backing plate. The new plate is marked Right Side. The backing plate that is on my axle is marked Left Side. The long shoe is facing forward. I know that this is wrong.
I can't recall if the backing plates came assembled on the new Henchen axles or not.... did I put the Left/Right backing plates on the wrong side of the axle or did I put the axle on 180deg backwards?
Oh my.... My 1 hr project just went to crap!
Laura
funkill is offline   Reply With Quote
Old 06-03-2010, 11:09 AM   #2
richinny's Avatar
2011 34' Classic
in which direction do the axle trailing arms point? pictures?
Ricky
Old 06-03-2010, 11:18 AM   #3
funkill's Avatar
reno , NV
Images: 27
Photo's ---- my flipping camera is dead and I can't find the charger --- on my to do list before tomorrow's trip. The thing won't even power on.
Ran outside to confirm - the wheel spindle is aft - so the torsion arm is trailing to ther rear of the trailer. Same way on both axles. That's good, right?
Old 06-03-2010, 11:22 AM   #4
richinny's Avatar
2011 34' Classic
yes :-) i'm not sure if you can even reverse them. i see you had lockup problems with the old axles too. possibly you followed what was there before and they were wrong then. in any case, you'll need to check at least 3 wheels. in the worst case, you'll have to swap sides on both axles.
Ricky
Old 06-03-2010, 11:26 AM   #5
funkill's Avatar
reno , NV
Images: 27
Thank you Ricky! I'll head back out to see what kind of mess I made for myself. With any luck, I'll only be checking 3 wheels! I'll report back in a couple hours!
Laura
Old 06-03-2010, 11:30 AM   #6
richinny's Avatar
2011 34' Classic
you should call andy. he should be part of this process.
Ricky
Old 06-03-2010, 01:31 PM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The curbside is the right side.
The street side is the left side.
I believe long shoe (secondary) should face rear ward.
>>>>>>>>>>>>>>>>>>>>>>Action
Old 06-03-2010, 03:55 PM   #8
funkill's Avatar
reno , NV
Images: 27
I spoke with another guy at Inland and they did not send me the axles pre-assembled with the backing plates. So, it's entirely my error in placing the left on the right side and vice versa. I went ahead and put the new backer plate on the correct side and am leaving the other side alone for now. It is raining cats & dogs, with a lot of lightening so... I'm done for the evening. I did repack the bearings though... The guy from Inland didn't think it would be too horrible if the backing plates on the other axle are also reversed. He said it would reduce my braking ability by about 10%. With that in mind, and the weather, I'm going to leave that axle alone until after my trip. Then I'll take a peak and see if I skrewed up that axle as well. I don't know how I made such a mistake. The LH/RH is the same convention as I'm used to working with on a daily basis (STBD/PORT). My only excuse is that I was way tired by the time I was finishing the rear axle when I was replacing them last year. Fingers are crossed that I did better on the first one (fwd axle). Thanks for you help guys....
Laura
Old 06-03-2010, 04:20 PM   #9
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have one pretty good picture. [OK mayby four pictures] I don't want to confuse you, so I will try to keep it simple. First the backing plate, by it'self, makes no difference. The shoes are the same except that one has more [longer] lining on it. The shoe with longer lining goes to the back of your trailer. The direction of the magnet arm makes a huge difference. The arm needs to be in front, so the magnet pulls toward the rear when activated.
(1.) Backing plate makes no difference if it has two brake adjustment holes. [Mine only has one hole so it has to go on the correct side] Note: this means a backing plate without anything on it.
(2.) Reversed shoes will effect brakeing, but not very much.
(3.) reversed magnet, means little or no braking at all. [going forward]
In the pictures posted, the two on top are of the left/street side rear brakes.
In the lower left picture is the right/curb side rear brake.
The last picture shows an empty baking plate. You can see the only difference is that it has only one off-set adjuster hole. You could use this on the wrong side, with the adjuster reversed, but it would confuse you when trying to adjust your brakes. These pictures should show you how the brakes should be. The shocks are in front of the axles, so that is the front of the trailer.
Name:	IMG_1996 (Large).JPG
ID:	103923   Click image for larger version
Name:	IMG_1997 (Large).JPG
Name:	IMG_2002 (Large).JPG
ID:	103925   Click image for larger version
Name:	IMG_2022 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-03-2010, 06:45 PM   #10
Laura
Laura.
The this way, no that way, can be very confusing.
Same is true for which is right side and left side.
When it comes to the electric brakes, there is no need to know the left from the right.
BUT always install the backing plates so that the arm that holds the magnet on, ALWAYS is closest to the front of the trailer.
That way, it makes the issue go away, like on a rocket.
You may not need the new backing plate after all, but keep it as a spare.
Old 06-03-2010, 07:01 PM   #11
We sent a PM to Laura, since we did not know her last name so that we could look up the records for her phone number.
She called me, I reviewed the issue and arranged to have a new backing plate sent to her asap.
She received it, but felt it might be wrong.
At this point, I feel that she now knows how to correct the problem.
My experience says that the brakes must be on the correct side, to make sure of proper performance and no ensuing lockups, as she has already experienced.
But after chatting with her, and knowing what work she does, I wager that she is now an electric brake master mechanic.
Go get em Laura.
Old 06-03-2010, 08:26 PM   #12
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Hey, props to Laura for changing the axles in the first place! I've been staring at my axle just trying to figure out how to jack the thing up... it sure feels heavy! Guess I gotta just give her a go.
Marc
Old 06-04-2010, 12:08 AM   #13
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Marc
A $20 rolling floor jack makes that job bunches easier, and something like cardboard will help slide an axle around. Floor jack will help you get that last 1/4 inch up on the last bolt before your back goes out.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 06-07-2010, 07:11 AM   #14
funkill's Avatar
reno , NV
Images: 27
Wowa-boy. My arm was hanging from the rear - backing plates definately on the reverse side! I installed the new backing plate sent promptly from Andy and left for my trip before seeing the additional posts. Before my next trip in July, I'll replace the other wrong backing plate on the street side and be *all good*. Man, the things you learn.... I still don't know how I made the mistake in the first place. They are clearly labeled and I understand the LH/RH convention. Anyone who installs/assembles the Henschen axles should have no problem with this! Well, other than human error.
Oh no, new question... the new backing plate has two adjustment holes (remaining 3 plates have one adjustment hole). How does adjustment differ with the two holes?
Laura
What Am I Doing Wrong? StingrayL82 Batteries, Univolts, Converters & Inverters 37 09-01-2009 05:29 PM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
What's wrong... rickandsandi Off Topic Forum 18 08-07-2007 05:59 PM
What is wrong with? 53flyingcloud On The Road... 20 06-15-2004 04:20 PM
Something wrong with.. 53flyingcloud Our Community 7 11-24-2003 02:30 PM
