Old 02-05-2012, 01:59 PM   #1
Anchorage , Alaska
Help connect dots: Axle rating + torsion spring + shock.
I am trying to educate myself on the wonderful world of torsion axels. I have built off road vehicles, I have broken leafs, bent leaf hangers, replaced leafs, and pretty much understand how leafs interact with shocks. Cannot say I completely understand the interplay of any suspension system, but at least I have seen a leaf spring before!
My 1963 Bambi is forcing me to try and understand torsion axels. ( rolled out of the factory with approx 1,800 lb dry weight at the axel). My understanding is that the original axel was a little inadequate, and though there is considerable debate, most replace the axel with a 3,500. Some of the Monday morning criticism over 3,500 axel is an overly rough ride.
Apparently each torsion axel, (with frame mounts) is pretty much a custom order in this neck of the woods. Can an axel & spindel rated to 3,500 lbs be ordered with rubber innardes for a lighter trailer?
How does one match an appropriate shock, for 3,500 torsion springs, under 1/2 the load? A shock will not soften stiff springs, but on the other hand it will do very little if the springs do not flex.
Aktundra is offline   Reply With Quote
Old 02-05-2012, 02:25 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have to disagree. All the Bambi's (61-63) came with torsion axles. The documents here: Airstream, Inc :: Specifications support that as well. I believe that 1960 was the at year for springs, but I am not 100% sure of that.
3500 lbs does seem like a lot of axle for an 1800 lbs trailer...
Richard
Old 02-05-2012, 02:36 PM   #3
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
I stand corrected!
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 02-05-2012, 05:50 PM   #4
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Ask Inland RV
Seeking axle rating advice Mr Jolly Axles 14 11-27-2011 06:20 AM
