Old 02-08-2009, 12:42 PM   #1
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin , 28734
HELP! axle trouble
My 1982 Excella axles are bolted in with 4 bolts per axle per side. The two bolts that go vertical have nuts that are not welded so when i try to back out the bolts they just spin. I got a wrench on the back two by cutting out the belly pan, but the front two are surounded by steel gussets. I can get a torch and blow the heads off of the front bolts but when i replace the axles there is no way to get the nuts on the vertical bolts. What can I do?
Ramp is offline   Reply With Quote
Old 02-08-2009, 01:01 PM   #2
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
never seen one with verticle bolts before, think I read once about someone else having a similiar problem. I know all 3 trailers we've had (all 60's models) have two horizontal bolts only on each side.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
wally:Restoring Wally Byam's 1955 26' European Caravan Trailer!
goransons is online now   Reply With Quote
Old 02-08-2009, 01:27 PM   #3
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin , 28734
I am sure that they are fractory installed. I just wish that they had welded the nuts to the frame.
Old 02-08-2009, 01:47 PM   #4
1963 24' Tradewind
San Diego , California
I don't have a visual, however can you have them welded on?
Sixty3TW4US is offline   Reply With Quote
Old 02-08-2009, 02:11 PM   #5
I am not aware of either Airstream plant "ever" using the vertical bolts.
That is why the axle moounting plates are used.
Use 2 bolts per side, thru the axle bracket, thru the axle mounting plate. That's how the axles were designed to be mounted for over 45 years.
You can burn them off with a torch, but be careful.
The aluminun can be patched if you burn it.
Old 02-08-2009, 06:24 PM   #6
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
Just helped my brother in law remove an axle yesterday (torched the bolts)....there were only two per side. I don't see the need for any going vertical. I would just remove them and forget about replacing.
94Tri is offline   Reply With Quote
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 11:37 PM
Will this cause me any trouble? flynmike Lights - Interior & Exterior 6 06-17-2007 02:20 PM
Are we in Trouble??? frank n'shar Member Introductions 25 11-01-2006 07:15 PM
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 05:15 AM
I may be in trouble..... wahoonc Our Community 7 10-11-2003 11:53 PM
